Dear Sir/Madam I have establish connection using TCP asyn module, and also received 100bytes TCP data, it is stored in let assume msg->buf. In which 10 are the float (i.e.40 bytes), 20 are the integers (20 bytes) and remaining are Boolean (i.e 20bytes). I have segregated floats, integers and Booleans, now i want to assign this to PV. Kindly help me how to make various records/database (.db file), and how to assign segregated received value to process variable. I am very new in record set/process varible/db file, kindly give one example of each. Regards Ritu
Jain
ANJ, 17 Dec 2015 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
