1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Binary record that recover its value after changed
To: [email protected], tech_talk <[email protected]>
Date: Thu, 13 Feb 2014 06:54:03 -0800
Antonio,
set the HIGH field of the binary output record to the number of seconds you want it to stay at 1.
- rolf -
On 2/13/2014 6:45 AM, Antonio Borondo wrote:
I have defined a binary output for a command in EPICS which always is 0. If the user change the value to 1 (by a CSS/BOY interface) it must change to 0 again after a few seconds. How can I do that?
Thank you very much,
Antonio Borondo
| Rolf Keitel, Ph.D.                Tel: (604) 222-7453 |
| TRIUMF                                                |
| Vancouver, B.C., Canada                               |
Re: Binary record that recover its value after changed Ralph Lange
RE: Binary record that recover its value after changed Antonio Borondo
Prev: Binary record that recover its value after changed Antonio Borondo
Next: Re: Binary record that recover its value after changed Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
