Hi Mark
Thanks. I managed to get it to work by running a normal script with this command, and then calling my 'st.cmd' from within the script.
Appreciate your quick response.
Amien
-----Original Message-----
Sent: Thursday, February 20, 2014 3:21 PM
To: Amien Crombie; [email protected]
Subject: RE: Running Linux commands inside 'st.cmd'
You can run Linux commands from st.cmd with the "system" command:
system "echo 113 > /sys/class/gpio/export"
However, the iocsh "system" command is not enabled by default for security reasons. This is from the IOC Application Developers Guide:
system command_string
Send command_string to the system command interpreter for execution. This command is present only if some application database definition file contains registrar(iocshSystemCommand) and if the system provides a suitable command interpreter (vxWorks does not).
From: [email protected] [[email protected]] on behalf of Amien Crombie [[email protected]]
Sent: Thursday, February 20, 2014 7:09 AM
To: [email protected]
Subject: Running Linux commands inside 'st.cmd'
Hi
I have the following ‘st.cmd’
#!../../bin/linux-arm/ioc48
< envPaths
cd ${TOP}
## Want to add the ‘echo’ Linux command but it fails ## echo 113 > /sys/class/gpio/export
dbLoadDatabase "dbd/ioc48.dbd"
ioc48_registerRecordDeviceDriver pdbbase
int32DriverInit("int32",-32768,32767)
dbLoadTemplate "db/iocPV.substitutions"
set_savefile_path("../save")
set_pass1_restoreFile("channelmap.sav")
set_pass1_restoreFile("channelspacing.sav")
save_restoreSet_DatedBackupFiles(1)
save_restoreSet_NumSeqFiles(3)
save_restoreSet_SeqPeriodInSeconds(6000)
save_restoreSet_RetrySeconds(120)
cd ${TOP}/iocBoot/${IOC}
iocInit
dbpf devx:range 1
Either EPICS’s st.cmd cannot run Linux commands or I’m doing something wrong.
Thanks
Amien
Cape Town
Mogamad Amien Crombie
NRF : iThemba LABS
EIT Group
Laboratory for Accelerator Based Sciences Somerset West, Western Cape South Africa
[cid:[email protected]]
- Running Linux commands inside 'st.cmd' Amien Crombie
- RE: Running Linux commands inside 'st.cmd' Mark Rivers
Re: Running Linux commands inside 'st.cmd' Andrew Johnson
<2014>
2025
<2014>
2025
