Subject: |
New version of LabVIEW-EPICS-interface CA Lab 1.5.0.1 can create new EPICS PVs now |
Carsten Winkler <[email protected]> |
To: |
tech-talk <[email protected]> |
Date: |
Mon, 24 Feb 2014 16:19:52 +0100 |
We are happy to bring you the improved version of our
LabVIEW-EPICS-interface CA Lab 1.5.0.1!
You can create new EPICS PVs and start a Soft IOC instance out of
LabVIEW now!
We have updated our website and have new examples to getting started.
http://www-csr.bessy.de/control/SoftDist/CA_Lab/
Change-log of CA Lab
V1.5.0.1 (Released: February 2014)
+++ New server component! +++
+ Configure and start an external "soft IOC shell" instance directly
out of LabVIEW (for Windows only, Linux users really doesn't need it)
+ New VI "CaLabInfo" to show:
current (used) EPICS environment variables
internal EPICS PV cache of CA Lab
# Error code for success is 0 now instead of 1
# Error codes are in user error code range now (7008-7496)
Ca Lab error {7008-7472} - 7000 = Channel Access error code
# Shows more error messages
# Solves problems with restarted VIs
# caLabGet: Solves problems with empty PV name array
# Removes delayed termination of VIs
(found a better way for safe termination)
# PV cache and subcriptions are running until all CA Lab VIs are closed
(stopped VIs have ongoing PV monitors for quick restart)
# Improved Linux compatibility
# EPICS base 3.14.12.4
Known problems (for Linux users only!!!)
Linux + current LabVIEW™ version: The event function is broken. (NI
confirmed the problem and looks for a solution.) The problem is in the
development enviroment only. If you build an executible, all is fine.
(NI 2014-02-24: "The problem is expected to be fixed with the version LV
2014.")
All suggestions and comments are welcome!
Cheers
Carsten
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Re: epics on beaglebone D Peter Siddons
Re: procServ softIOC server - V2.6.0 released Pavel Maslov
<2014>
<2014>
