1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: Autosave an array field (not record)
To: "Zhang, Dehong" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 27 Feb 2014 20:48:38 +0000
Hi Dehong,
What you're doing is supposed to work, and I do it routinely with arrays of doubles, ints, and chars. I haven't been able to get the symptom you describe to happen.  Can you give more information about the PV and
whatever else you think might help me reproduce this?
Tim
From: [email protected] [[email protected]] on behalf of Zhang, Dehong [[email protected]]
Sent: Thursday, February 27, 2014 1:49 PM
To: [email protected]
Subject: Autosave an array field (not record)
Is there a way to do this?  Do I have to use a waveform record and feed the waveform
to the desired field (of another record)?
In my request file, I have this array field in the same way like any other scaler field.
However in the auto-generated .sav file, the filed IS commented out with "#", with "Connected"
after the name of the field, but no values at all (nothing like the @array@ { ...).
Please advice.  Thank you very much.
Dehong
Autosave an array field (not record) Zhang, Dehong
Prev: Autosave an array field (not record) Zhang, Dehong
Next: Re: Trouble with caget with denSnmp Nicoletta Petrella
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: EPICS base-3.14.12.4 make Error zuo.jiao
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
