display.getWidget("t_display").setPropertyValue("text", i+"_"+value1+"_"+value2); display.getWidget("t_display").getPV(); But I got error "cannot convert Swati_soni_value1_value2 to java.lang.Integer Thanks & Regards Swati Hello All. I am getting trouble to get value of attached PV from CSS widget. Here is my script: importPackage(Packages.org.csstudio.opibuilder.scriptUtil); var i = "Swati_Soni"; var value1 = display.getWidget("text1").getValue(); var value2 = display.getWidget("text2").getValue(); display.getWidget("t_display").setPropertyValue("text", i+"_"+value1+"_"+value2); From this script I am able to concatenate the two value in textupdate "t_display" (widget shows the output), but the PV attached into it can not get updated with this concatenated value. Is there any method so that the attached PV of "t-display"can be updated with "Swati_Soni_value1_value2". text1 and text2 has=ai EPICS record ,whereas t_display has stringin record. Thanks in advance, Swati =====-----=====-----=====
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
