1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CSS BEAST alarm hierarchy
To: [email protected]
Date: Thu, 06 Mar 2014 15:26:48 +0100
at ANKA we have implemented filtering, which filters alarms regarding the operation mode. When machine is in shutdown or maintenance, most of alarms are suppressed, before they reach CSS BEAST.
All our alarms are feed into our intermediate alarm server, which decided if they should go further to BEAST or be suppressed or be somehow otherwise processed. For example have summary alarm PV, which sums alarms from whole subtree. Our intermediate alarm server is based on JCA and looks like bunch of plain PV channels which are used by BEAST. No changes were made to BEAST, everything is in configuration.
Enable feature of BEAST I see more like permanent switch, if you want to disable misbehaving alarm source.
Hope this helps,
Igor
On 05.03.2014 04:39, [email protected] wrote:
Hi
We are currently using BEAST. There is the ability to put alarm system in Maintenance mode. But it puts the whole entire system in Maintenance mode. We would like to be able to put an Area or a System in maintenance mode.
I’m wondering if there is any plan to implement such feature. Or would anyone else find this feature useful?
We have started investigating this implementation. Essentially the ENABLED_IND database field should be move to ALARM_TREE table from PV table, and isEnable() should be a base class method.
Xinyu WU
ASKAP Computing
Australia Telescope National Facility
CSIRO Astronomy and Space Science
phone: +61 2 9372 4727
postal: PO Box 76 Epping, NSW. 1710
Re: CSS BEAST alarm hierarchy Kasemir, Kay
CSS BEAST alarm hierarchy Xinyu.Wu
Prev: Re: Sequencer is not monitoring Pvs from another IOC Benjamin Franksen
Next: Re: Sequencer is not monitoring Pvs from another IOC Ganesh Jangir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: CSS BEAST alarm hierarchy Kasemir, Kay
Next: Re: CSS BEAST alarm hierarchy Kasemir, Kay
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
