1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: MAXv model-3 driver - omsMAXvConfig problem
To: <[email protected]>, <[email protected]>
Date: Fri, 7 Mar 2014 14:44:27 +0000
Hi Kristi,
Yes, it would be helpful to know what you mean. Do you think that the card is failing to respond to the commands, or that the commands are not propagating down to the card? Is it an intermittent problem? Could you enable the asyn trace before the call to config2?
I have had problems with 'new' OMS cards being configured with non-default settings, so I always have RDF as my first command in the configuration string.
Austen Rose
(x8495)
-----Original Message-----
Sent: 07 March 2014 12:18
To: Luchini, Kristi L.; [email protected]
Can you be more specific about what you mean by "the axis configuration settings don't always seem to stick for every axis"?
Do  you mean they are not restored correctly after a reboot?  Or do they get lost while the IOC is running?
From: [email protected] [[email protected]] on behalf of Luchini, Kristi L. [[email protected]]
Sent: Thursday, March 06, 2014 6:48 PM
To: [email protected]
Subject: MAXv model-3 driver -  omsMAXvConfig  problem
Hello,
We have seen a problem with  the MAXv omsAsyn support,  where the axis configuration settings don't always seem to Stick for every axis. We have a temporary workaround, where to use the MAXv command "APP" which saves the configuration settings as the Power-up default.
Has anyone implemented a solution to this problem?
Details:
EPICS R4.13.12
RTEMS-R4.9.4
MVME6100
MAXv-8000  FW 1.44
 - Regard,
  Kristi
MAXv model-3 driver - omsMAXvConfig problem Luchini, Kristi L.
RE: MAXv model-3 driver - omsMAXvConfig problem Mark Rivers
Prev: Re: Sequencer is not monitoring Pvs from another IOC Benjamin Franksen
Next: RE: MAXv model-3 driver - omsMAXvConfig problem Luchini, Kristi L.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: MAXv model-3 driver - omsMAXvConfig problem Mark Rivers
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
