1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: MAXv model-3 driver - omsMAXvConfig problem
To: "D'Ewart, J. Mitch" <[email protected]>
Cc: "Luchini, Kristi L." <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 12 Mar 2014 17:43:29 +0100
Hi Mitch,
OK, I added another 500ms delay before the init string.
Thanks
Jens
_______________________________
Jens Eden
Physikalisch-Technische Bundesanstalt
Albert-Einstein-Straße 15
12489 Berlin
Tel +49 30 3481-7160
Von:    "D'Ewart, J. Mitch" <[email protected]>
An:     Jens Eden <[email protected]>, "Luchini, Kristi L."
Kopie:  "[email protected]" <[email protected]>
Datum:  11.03.2014 17:50
Betreff:        RE: MAXv model-3 driver -  omsMAXvConfig  problem
Hi Jens,
We've noticed the same thing with one addition. - we also had to add a
delay before the init string (after the AM SA;).  Some of the commands
were not being setup properly if they were sent immediately after the "AM
SA;" command.
Mitch D'Ewart
Behalf Of Jens Eden [[email protected]]
Sent: Monday, March 10, 2014 3:16 AM
To: Luchini, Kristi L.
Cc: [email protected]
Subject: Re: MAXv model-3 driver -  omsMAXvConfig  problem
Hi Kristi,
I noticed that the "LT" command in the init string is not always processed
properly.
Varying the order of commands in the init string shows different results.
The latest MAXv driver (https://subversion.xor.aps.anl.gov/synApps/motor/)
has a 500ms delay
to workaround this problem. That did it my case.
Jens
Am 07.03.2014 17:59, schrieb Luchini, Kristi L.:
> Hi ,
> Below is an email that Mitch sent to the manufacturer, pro-dex this
morning , that has  more details.
> I'm not sure, but I suspected that the problem is setting the
configuration,  I don't think there's a read-back of the configuration in
omsMAXvConfig() that verifies the setting request, and then issues an
error message if there's a mismatch.  Mitch's system setup is different
than mine, but the  result seems to be the same.
> I recall that Arturo had said this problem didn't occur with the VME
MAXv driver, but I can test this in development.
> In my case, which occurred a few months ago, during the upgrade of
production application, to
> 1) the new motor module
> 2)  asyn MAXv driver,
> 3) from CAMAC to VMS
> 4) in some instances, newly installed (if not new) hardware, like driver
controllers, encoders and such
>   the limit switches, as far as I know were not disconnected, as they
were in Mitch's case.  I will try to reproduce this problem
>   today  in development, and see if I can provide more details. I hope
this helps.
> Regards,
> - Kristi
> -----Original Message-----
> From: D'Ewart, J. Mitch
> Sent: Friday, March 07, 2014 8:17 AM
> To: [email protected]
> Cc: Williams Jr., Ernest L.; Oven, Ziga; Luchini, Kristi L.
> Subject: MAXv Configuration
> Hi Reto,
> I'm working the MAXv and have noticed some odd behavior.  I am using the
MAXv (OMS Firmware Version is: /MAXv-8000 ver:1.44, s/n:001457, FPGA:B6:A7
BOOT:1.3 - Oregon Micro Systems) with normally closed limit switches.  On
boot up I send an initialization string to the MAXv:
> "AX LTH PSM; AY LTH PSO"
> I noticed that with the limit switches plugged in (NC) the LT command
does not get processed properly ("AX LT?" returns "=l").  However if the
limit switches are not plugged in "AX LT?" reports "=h".
> I found that the driver sends "AM SA;" immediately before the Init
string.  Playing around with it a bit I found that if I send a string "AM
SA; AX LTH PSM; AY LTH PSO" with limits connected I get "AX LT?" "=l".  If
I send the same command string with limits disconnected I get "AX LT?"
"=h".
> Does the "AM SA;" flush some sort of command queue?  Why does the limit
switch being connected matter?  Why isn't the "PS" command affected, are
there any other axis commands that could respond the same way?  What is
the best way to handle this, put a delay after "AM SA;"?  Thanks,
> Mitch D'Ewart
> From: Mark Rivers [mailto:[email protected]]
> Sent: Friday, March 07, 2014 4:18 AM
> To: Luchini, Kristi L.; [email protected]
> Can you be more specific about what you mean by "the axis configuration
settings don't always seem to stick for every axis"?
> Do  you mean they are not restored correctly after a reboot?  Or do they
get lost while the IOC is running?
> Mark
> From: [email protected] [[email protected]] on
behalf of Luchini, Kristi L. [[email protected]]
> Sent: Thursday, March 06, 2014 6:48 PM
> Subject: MAXv model-3 driver -  omsMAXvConfig  problem
> Hello,
> We have seen a problem with  the MAXv omsAsyn support,  where the axis
configuration settings don't always seem to Stick for every axis. We have
a temporary workaround, where to use the MAXv command "APP" which saves
the configuration settings as the Power-up default.
> Has anyone implemented a solution to this problem?
> Details:
> EPICS R4.13.12
> RTEMS-R4.9.4
> MVME6100
> MAXv-8000  FW 1.44
>   - Regard,
>    Kristi
MAXv model-3 driver - omsMAXvConfig problem Luchini, Kristi L.
RE: MAXv model-3 driver - omsMAXvConfig problem Mark Rivers
RE: MAXv model-3 driver - omsMAXvConfig problem Luchini, Kristi L.
Re: MAXv model-3 driver - omsMAXvConfig problem Jens Eden
RE: MAXv model-3 driver - omsMAXvConfig problem D'Ewart, J. Mitch
Prev: Re: Another build-system bug in 3.14.12 Andrew Johnson
Next: RE: MAXv model-3 - error reading axis position after 5 attempts Jens . Eden
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: MAXv model-3 driver - omsMAXvConfig problem D'Ewart, J. Mitch
Next: Store array of strings in EPICS record Ganesh Jangir
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
