1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: BEAST screencast?
To: Emmanuel Mayssat <[email protected]>
Cc: EPICS mailing list <[email protected]>
Date: Wed, 19 Mar 2014 17:10:22 -0400
Hi:
You can look at paper/talk from the Kobe 2009 meeting, copies are also on http://ics-web.sns.ornl.gov/kasemir/CSS/
For setup info, see http://ics-web.sns.ornl.gov/kasemir/CSS/
To get a useful setup, see B. Hollifield, E. Habibi, "Alarm Management: Seven Effective Methods for Optimum Performance", ISA, 2007
At the SNS, this is at least the 3rd attempt on an alarm system.
Compared to ALH, BEAST makes it even easier to add PVs.
The functionality is pretty simple: PV goes into alarm -> Notify operators of alarm, operators acknowlege, handle it, done.
The really hard part: Don't add 5000 PVs, about half of them happen to be in alarm, none have any guidance, links to related displays, many are redundant -> Totally useless.
Instead, you need to think quite hard about every single alarm:
What should operators _do_ ASAP when this alarm happens?
Is this the best PV for that situation, or would other PVs also catch the same scenario and make for an overall better alarm trigger? Maybe create a new PV for this type of alarm, with options to (automatically) disable based on machine state.
THEN add that PV to the alarm system, with guidance, links to related display, maybe web links to procedures.
Kay
Sent: Wednesday, March 19, 2014 3:52 PM
To: Kasemir, Kay
Subject: BEAST screencast?
Kay,
I hope you are doing well.
I am interested in having a closer look at the BEAST alarm handler.
I am particularly interested in the operator perspective.
Is there any public screencast on how BEAST is used at ORNL?
I am also interested in understanding the feature set of the alarm server.
is there any documentation about it?
Emmanuel
BEAST screencast? Emmanuel Mayssat
Prev: BEAST screencast? Emmanuel Mayssat
Next: softIOC through network file system Jeong Han Lee
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
