On 20.03.2014 11:59, Jeong Han Lee wrote:
We have one network file server (A), where I installed EPICS and
its extensions in /data/programs/epics/{base,extensions}. In A,
EPICS_BASE is /data/programs/epics/base.
We mount the directory as /mnt/glusterfs on a local Linux PC (B),
all uid and gid is the same. In B, EPICS_BASE is
/mnt/glusterfs/programs/epics/base.
The main issue which I've found until now (maybe something more
hidden issues, because I didn't test it fully) on softIOC, which has
the Compiled-in path inside the binaray files. Just shortly look at
Makefile and softMain.cpp, and makeInstallDir.pl, the EPICS path is
saved into the binary file when it compiles.
I know how to work around this issue by using softIOC -D option.
However, I know EPICS community has the better solution, any
suggestions, or potential issues which I don't know right now.
Hello Han,
I would not recommend this setup.
While putting executables and libraries on an NFS share is easy and Just
Works [tm] when you set it up, it will create painful difficulties later on.
To work reliably, *all* client machines need to be on (more or less) the
same version of the same Linux distribution. Any crucial change in the
system libraries of a client, and everything on that client might stop
working immediately (the easy case) or just become instable and
sometimes crash for no obvious reasons (the painful case).
In such a setup, updating your machines to a new Linux version becomes
basically an all-or-nothing operation, requiring a huge time slot for
testing and verification. Also, your development machine will always
have to be on the oldest version around, to generate code that is
compatible with all your client machines.
Using an NFS share is fine for all non-binary data (EPICS IOC databases,
startup scripts, autoSaveRestore data, logs, ...), but I would always
recommend keeping binaries and libraries locally on your production
machines. The easiest and safest way is to use your system's style of
binary packages, but rsync'ing from your development machine is
basically fine, too - in that case you are responsible for tracking the
dependencies.
If you put the installation in the same place on all machines, that
could be the path that you compile into the softIOC.
Note, though, that this softIOC binary in base is intended for
development use. Most of your real-life soft IOCs will need driver code
(asyn, stream, ...) and come as binaries that are created in an IOC
application, and then deployed on your production systems.
Cheers,
~Ralph
- RE: softIOC through network file system Mark Rivers
- Re: softIOC through network file system Jeong Han Lee
- softIOC through network file system Jeong Han Lee
<2014>
<2014>
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
