I should also add that CSS Boy is written in Java, and Java itself does not have native support for unsigned integer data types. It does have the data type "char", which is actually an unsigned 16-bit integer in Java.
Interestingly ImageJ treats 16-bit integer images as unsigned, and you have to play some tricks to get it to display signed 16-bit integers correctly, and that is also written in Java!
Sent: Thursday, March 20, 2014 2:43 PM
To: Hu, Yong; [email protected]; [email protected]
Subject: RE: CSS BOY and 16-bit Images
The problem is that EPICS CA does not have native unsigned data types. For efficiency 16-bit image data normally uses a waveform record with FTVL=SHORT. areaDetector has an ancillary PV that indicates whether the waveform is epicsInt16 or epicsUInt16. CSS BOY should be using this PV to determine how to display the data.
From: [email protected] [[email protected]] on behalf of Hu, Yong [[email protected]]
Sent: Thursday, March 20, 2014 2:36 PM
To: [email protected]; [email protected]
Hi Gabriele,
Before we conclude that the problem is related to BOY, please use "caget your_image_pv" (or caget -#number your_image_pv) to see what kind of image data you really get. If you find the data really containing negative values such as "-1" (I saw this kind of image data when I worked on Prosilica GigE camera), probably your camera is not properly configured through the AreaDetector driver.
If you are sure the image data are all OK with the range you expect (i.e. [0, 65535]), I guess the problem is most likely related to the configuration of the BOY Intensity Graph. Make sure you configure the following properties of the BOY Intensity Graph appropriately based on your camera configuration: Data Height, Data Width, Maximum, Minimum, Color Map, etc.
Give us more info such as your CSS version, image snapshots of the BOY & ImageJ, result of "caget your_image_pv".
Yong
From: [email protected] [[email protected]] on behalf of Gabriele Salvato [[email protected]]
Sent: Thursday, March 20, 2014 10:44 AM
Subject: CSS BOY and 16-bit Images
Hi all,
I use an Intensity Graph widget in a CSS-BOY opi, to show a
preview of the images collected by an Andor camera using AreaDetector.
The images are 16 bit gray level ones (ranging from 0 to 65535).
The widget is connected with a PV (ArrayData) that is the
same I use with the ImageJ plugin distributed with AreaDetector.
The problem is that the widget displays correctly only the pixels
with gray levels < 32767 and interpret grater gray values as negative
numbers (16th bit =1).
On the contrary, ImageJ displays correctly he entire image.
Is there any way to overcome this problem with the BOY widget ?
Thank you,
Gabriele Salvato
- RE: CSS BOY and 16-bit Images Janez Golob
- CSS BOY and 16-bit Images Gabriele Salvato
- RE: CSS BOY and 16-bit Images Hu, Yong
- RE: CSS BOY and 16-bit Images Mark Rivers
Battery Cycler tom.cobb
<2014>
<2014>
