The calcout record also has fields indicating the states of its input links.
record(calcout, "all_ok") {
field(INPA, "ioc1_pv")
field(INPB, "all_ok.INAV")
Tim
Dear All,
I have multiple IOC(say 4) on 4 linux (Fedora, 64bit) machines over network. Each IOC also have running Sequencer program.
Sequencer of each IOC need to be aware of every IOC if they are running or not/ machine connected or not, before doing some task.
How to do this?
I tried using CALC Record. Its 4 INP fields gets some particular value from four different IOC and calculate some new value,By interpreting this value Sequencer come to know about the connected IOC.
The problem is that , in case of some disconnection of IOC , its INP fields picking old values. And CALC record gives same value in each case.
Is this right approach for many IOCs? How to make INP fields, to give different value in case of disconnection of some IOC.
Second, I also tried using pvConnected() function of sequencer. But it starts giving error messages incase of disconnection, before checking it.
___________________________________________________
I am using
Epics base-3.14.12.3
Sequencer seq-2.1.16
OS: Linux Fedora 19 64bit
I have following settings.
export EPICS_ROOT=/home/ganesh/epics
export EPICS_HOST_ARCH=linux-x86_64
export EPICS_BASE=$EPICS_ROOT/base-3.14.12.3
export EPICS_EXTENSIONS=$EPICS_ROOT/extensions
export EPICS_CA_ADDR_LIST="192.168.8.2 192.168.8.3 192.168.8.4 192.168.8.5"
export MOTIF_LIB=/usr/lib64/
export SEQ=$EPICS_ROOT/extensions/seq-2.1.16
export PATH=/sbin:/bin:/usr/sbin:/usr/bin:$file:$EPICS_ROOT/base-3.14.12.3/bin/linux-x86_64:/bin/linux-x86_64
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$EPICS_BASE/lib/$EPICS_HOST_ARCH:$EPICS_EXTENSIONS/lib/$EPICS_HOST_ARCH
__________________________________________________________________
Best Regards
Ganesh
Notice: The information contained in this e-mail
message and/or attachments to it may contain
confidential or privileged information. If you are
not the intended recipient, any dissemination, use,
review, distribution, printing or copying of the
information contained in this e-mail message
and/or attachments to it are strictly prohibited. If
you have received this communication in error,
please notify us by reply e-mail or telephone and
immediately and permanently delete the message
and any attachments. Thank you
- How to check if IOC is connected or not? Ganesh Jangir
Re: How to check if IOC is connected or not? Pearson, Matthew R.
<2014>
<2014>
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
