Pete, I don’t believe this is an issue with building EPICS Base. I bet you moved to a new HOST machine, right? I had to ADD into the top level CONFIG (or was it RELEASE?) and OS/CONFIG the x86_64 target setups because I’m building on an AMD 64 Bit CPU.
And/Or someone forgot to add this setup as part of the release update I’ve built for x86_64 under 3.14.12.4 and 3.15.0.1 successfully. Regards, Stephen Beckwith Embedded Linux Engineer - Timesys Corp.
On Tue, Apr 1, 2014 at 4:08 PM, D Peter Siddons <[email protected]> wrote: Hi Andrew,
ANJ, 17 Dec 2015 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
