1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: How to stop acquire in DblCorrelation Mode for MarCCD in AreaDetector module
To: 周平 <[email protected]>, tech-talk <[email protected]>
Date: Wed, 9 Apr 2014 11:24:07 +0000
Hi Zhou Ping,
I was not aware of this problem.  I will test it today and see if I can reproduce it and find a solution.
From: [email protected] [[email protected]] on behalf of 周平 [[email protected]]
Sent: Wednesday, April 09, 2014 2:38 AM
To: tech-talk
Subject: How to stop acquire in DblCorrelation Mode for MarCCD in AreaDetector module
Hi All,
The detector of our beamline is MarCCD and the type is SX165. It worked in  areaDetectorR1-9-1 Module correctly.  The parameters were as follows:
    ADFrameType = DblCorrelation;
    ADImageMode = Single;
    marCCDStability = 0;
    marCCDOverlap = Sequential;
    In this condition, I found it can't stop acquire completely when it was acquiring. It can only stop front half acquire time and the back time can't stopped. For example, if I set the acquire time = 100s, then I clicked the start button to start acquire. If I want to stop acquire when it had acquired 20s for front half the nominal acquisition time, I clicked the stop button to stop it.  And then I found it still acquired in the next half the nominal acquisition time which was 50s. It couldn't be stopped completely!
    If I set ADFrameType to Normal, it could be stopped quickly. But the background noise was too large in this mode so I set ADFrameType to DblCorrelation for use.
    Is there a way to solve this problem?
    Thanks!
With best regards,
Zhou Ping
SAXS Beamline, SINAP, Chinese Academy of Sciences
Address:239 ZhangHeng Road,Pudong District,Shanghai,201203,P.R.China
Tel:86-21-33932019    Mobile: 86-18116357596
Email:[email protected]
RE: How to stop acquire in DblCorrelation Mode for MarCCD in AreaDetector module Mark Rivers
How to stop acquire in DblCorrelation Mode for MarCCD in AreaDetector module =?gb18030?b?1tzGvQ==?=
Prev: How to stop acquire in DblCorrelation Mode for MarCCD in AreaDetector module =?gb18030?b?1tzGvQ==?=
Next: EDM - where to find widget "Variable Scale Bar" Joachim Rahn
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: How to stop acquire in DblCorrelation Mode for MarCCD in AreaDetector module Mark Rivers
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
