1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: [CSS] freeze and lost running PV in Boy Screens
To: Maurizio Montis <[email protected]>
Date: Thu, 1 May 2014 08:26:12 -0400
Hello Maurizio:
As Jeff already replied, the Channel Access server on the IOC should not be affected by the specific order in which CA clients do things.
The issue may indeed be in the driver support for your VME hardware.
Still, if you want to narrow the issue down from the CSS side, try CSS versions 3.1.x (for SNS, you can find those older ones on https://ics-web.sns.ornl.gov/css/updates/apps/?C=M;O=D).
CSS 3.2 uses the PVManager, 3.1 doesn't, so that would allow you to compare the behavior with two different CA client implementations.
Kay
On Apr 30, 2014, at 5:33 PM, Maurizio Montis <[email protected]> wrote:
> .. when i open the slow popup and after open the fast without closing the
> previous one..
> * i also tried to change the CSS version, using all the versions
> available from SNS site (BASIC versions from 3.2.1 to 3.2.16) but i had
> always the same situation.
Re: [CSS] freeze and lost running PV in Boy Screens Maurizio M .
[CSS] freeze and lost running PV in Boy Screens Maurizio Montis
Prev: RE: [CSS] freeze and lost running PV in Boy Screens Hill, Jeff
Next: Re: EDM X-Y Graph Scott Baily
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: [CSS] freeze and lost running PV in Boy Screens Maurizio M .
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
