1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: Device/Driver Support for Stepper Motor Control
To: 'Weiwei Lu' <[email protected]>, Ron Sluiter <[email protected]>
Date: Tue, 6 May 2014 19:51:48 +0000
Yes, it supports soft IOC, and yes you use drvAsynIPPort.  You pass the name of the asynIPPort as the third argument to the omsMAXnetConfig command.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Weiwei Lu
Sent: Tuesday, May 06, 2014 2:43 PM
To: Ron Sluiter
Cc: [email protected]
Subject: Re: Device/Driver Support for Stepper Motor Control
Hi Ron,
Thank you for the swift reply.  Just want to verify that Jens' asyn motor support for OMS MAXnet controller does support soft IOC, correct?  Besides, should I use asyn drvAsynIPPort as the driver support with Jen's asyn motor support?
William Lu
----- Original Message -----
To: "Weiwei Lu" <[email protected]>, [email protected]
Cc: "Jens Eden" <[email protected]>
Sent: Tuesday, May 6, 2014 3:26:00 PM
Hello William,
Jens Eden (PTB) added asyn motor support for both the OMS MAXv and the OMS MAXnet controllers. That support is available beginning with the latest release (R6-8) of the motor module.
Ron
On 5/6/2014 2:18 PM, Weiwei Lu wrote:
We plan to use a soft IOC and an OMS MAXnet motion controller to control a stepper motor.  The soft IOC will communicate with the MAXnet motion controller's Ethernet interface.  What are the existing EPICS device/driver supports that we can use for this soft IOC application?  Can APS's Stepper/DC Motor Controller software or Mark Rivers' devMotorAsyn and drvMotorAsyn be used for this?  What are the pros and cons comparing these two technologies?  Are there other alternatives?
Advice is greatly appreciated.  Thank you in advance.
William Lu
Re: Device/Driver Support for Stepper Motor Control Jens Eden
Re: Device/Driver Support for Stepper Motor Control Ron Sluiter
Re: Device/Driver Support for Stepper Motor Control Weiwei Lu
Prev: RE: Device/Driver Support for Stepper Motor Control Mark Rivers
Next: Re: Trouble with OID name using devsnmp. Nicoletta Petrella
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: Device/Driver Support for Stepper Motor Control Weiwei Lu
Next: Re: Device/Driver Support for Stepper Motor Control Jens Eden
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
