1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Newport XPS-Q8 and Motor Record - armv5teb architecture
To: <[email protected]>
Date: Wed, 7 May 2014 11:28:37 -0500
On 5/7/14, 11:01 AM, Jens Eden wrote:
> I don't know if this is the cause of the problem, but even on a
> single architecture, you will need a correct entry in this switch in
> motorApp/MotorSrc/motor.h
Jens posted about this to the list in February:
  http://www.aps.anl.gov/epics/tech-talk/2014/msg00158.php
>From that thread, it sounds like the motor module needs some work to
eliminate assumptions about, as Till Straumann wrote, "what storage unit
the compiler uses, how adjacent bits are packed across a storage-unit
boundary and in what order bits are allocated (LSB->MSB or MSB->LSB)."
Lewis
RE: Newport XPS-Q8 and Motor Record - armv5teb architecture Mark Rivers
Re: Newport XPS-Q8 and Motor Record - armv5teb architecture J. Lewis Muir
Re: Newport XPS-Q8 and Motor Record - armv5teb architecture Stephen Beckwith
Re: Newport XPS-Q8 and Motor Record - armv5teb architecture Jens Eden
Prev: Re: Newport XPS-Q8 and Motor Record - armv5teb architecture Jens Eden
Next: RE: Newport XPS-Q8 and Motor Record - armv5teb architecture Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
