1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: no response first time, so I'm trying again
To: EPICS Tech-Talk <[email protected]>
Date: Fri, 16 May 2014 16:33:45 +0200
On 16/05/2014 13:14, Pierrick Hanlet wrote:
I ran 4 tests to compare what happens when between running from the command line and using procServ
with port 5064 vs an arbitrary port 10000.  In all cases $EPICS_CA_AUTO_ADDR_LIST=NO.  For the cases
when I used procServ, I also did a tcpdump.
When running both IOCs from terminals with:
1) $EPICS_CA_ADDR_LIST="xxx.xxx.xxx.xxx:5064  and $EPICS_CA_SERVER_PORT=5064  yyy.yyy.yyy.yyy:5064":  2 IOCs work together
2) $EPICS_CA_ADDR_LIST="xxx.xxx.xxx.xxx:10000 and $EPICS_CA_SERVER_PORT=10000 yyy.yyy.yyy.yyy:10000": 2 IOCs work together
These results were expected.
I am puzzled by these lines.
Considering the dollar sign characters, the mentioned quoting, and no 'export' statement, this does not really make much sense to me.
I think I know what you mean, but I may as well be wrong.
Could you please clarify which settings apply to IOC1 and which settings apply to IOC2?
~Ralph
problem with procServ and server port numbers Pierrick Hanlet
no response first time, so I'm trying again Pierrick Hanlet
Prev: RE: no response first time, so I'm trying again Mark Rivers
Next: RE: [CSS] freeze and lost running PV in Boy Screens Maurizio Montis
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Point Grey Flea3 areaDetector ImageJ Viewer Problems Zachary Brown
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
