From the Makefile that I see:
http://bazaar.launchpad.net/~info-martin-konrad/epics-gateway/putlog/view/head:/Makefile
You set:
USR_CXXFLAGS_DEFAULT += -DWITH_CAPUTLOG
Now if you are also setting USR_CXXFLAGS_Linux, it will use this flag on
Linux and the DEFAULT on other operating systems. You might try changing:
to
USR_CXXFLAGS += -DWITH_CAPUTLOG
--Bob Soliday
On 05/19/2014 12:45 PM, Konrad, Martin wrote:
I'm experiencing the following issue with the EPICS build system:
I'm compiling the gateway code with our PutLog extensions [1]. This
requires setting CAPUTLOG=/usr/lib/epics on my Debian machine.
Everything works fine if I just run make. g++ is called with
"-DALLOW_CAPUTLOG" as it is supposed to be.
However, if I run make "USR_CXXFLAGS_Linux=-Werror=format-security" (one
of the parameters used when compiling Michael's Debian package), g++ is
not called with "-DALLOW_CAPUTLOG" anymore. It seems to ignore the
CAPUTLOG entry in the configure/RELEASE file.
Am I missing something or is this a bug?
Martin
P.S.: You can download a tarball [2] of my directory to reproduce the issue.
[1] https://code.launchpad.net/~info-martin-konrad/epics-gateway/putlog
[2] https://www.martin-konrad.net/gateway.tar.bz2
- RELEASE macro vanishes if USR_CXXFLAGS_Linux is set Konrad, Martin
Re: RELEASE macro vanishes if USR_CXXFLAGS_Linux is set Andrew Johnson
<2014>
<2014>
