Hi Mark, The output is as below. # ls -l /opt/epics/base-3.14.12.4/lib/linux-x86_64 total 35360 -r--r--r--. 1 root root 176698 Jun 20 21:01 libasHost.a lrwxrwxrwx. 1 root root 17 Jun 20 21:01 libasHost.so -> libasHost.so.3.14 -r-xr-xr-x. 1 root root 114531 Jun 20 21:01 libasHost.so.3.14 -r--r--r--. 1 root root 294910 Jun 20 21:01 libasIoc.a lrwxrwxrwx. 1 root root 16 Jun 20 21:01 libasIoc.so -> libasIoc.so.3.14 -r-xr-xr-x. 1 root root 176746 Jun 20 21:01 libasIoc.so.3.14 -r--r--r--. 1 root root 5424746 Jun 20 21:00 libca.a -r-xr-xr-x. 1 root root 239663 Jun 20 21:01 libCap5.so -r--r--r--. 1 root root 5223816 Jun 20 21:01 libcas.a lrwxrwxrwx. 1 root root 13 Jun 20 21:00 libca.so -> libca.so.3.14 -r-xr-xr-x. 1 root root 2618677 Jun 20 21:00 libca.so.3.14 lrwxrwxrwx. 1 root root 14 Jun 20 21:01 libcas.so -> libcas.so.3.14 -r-xr-xr-x. 1 root root 2103889 Jun 20 21:01 libcas.so.3.14 -r--r--r--. 1 root root 3098224 Jun 20 21:00 libCom.a lrwxrwxrwx. 1 root root 14 Jun 20 21:00 libCom.so -> libCom.so.3.14 -r-xr-xr-x. 1 root root 1468984 Jun 20 21:00 libCom.so.3.14 -r--r--r--. 1 root root 2271060 Jun 20 21:01 libdbIoc.a lrwxrwxrwx. 1 root root 16 Jun 20 21:01 libdbIoc.so -> libdbIoc.so.3.14 -r-xr-xr-x. 1 root root 1207310 Jun 20 21:01 libdbIoc.so.3.14 -r--r--r--. 1 root root 748512 Jun 20 21:00 libdbStaticHost.a lrwxrwxrwx. 1 root root 23 Jun 20 21:00 libdbStaticHost.so -> libdbStaticHost.so.3.14 -r-xr-xr-x. 1 root root 365668 Jun 20 21:00 libdbStaticHost.so.3.14 -r--r--r--. 1 root root 801568 Jun 20 21:00 libdbStaticIoc.a lrwxrwxrwx. 1 root root 22 Jun 20 21:00 libdbStaticIoc.so -> libdbStaticIoc.so.3.14 -r-xr-xr-x. 1 root root 397675 Jun 20 21:00 libdbStaticIoc.so.3.14 -r--r--r--. 1 root root 63612 Jun 20 21:01 libdbtoolsIoc.a lrwxrwxrwx. 1 root root 21 Jun 20 21:01 libdbtoolsIoc.so -> libdbtoolsIoc.so.3.14 -r-xr-xr-x. 1 root root 44557 Jun 20 21:01 libdbtoolsIoc.so.3.14 -r--r--r--. 1 root root 3603396 Jun 20 21:01 libgdd.a lrwxrwxrwx. 1 root root 14 Jun 20 21:01 libgdd.so -> libgdd.so.3.14 -r-xr-xr-x. 1 root root 1703552 Jun 20 21:01 libgdd.so.3.14 -r--r--r--. 1 root root 130740 Jun 20 21:01 libmiscIoc.a lrwxrwxrwx. 1 root root 18 Jun 20 21:01 libmiscIoc.so -> libmiscIoc.so.3.14 -r-xr-xr-x. 1 root root 76289 Jun 20 21:01 libmiscIoc.so.3.14 -r--r--r--. 1 root root 1190828 Jun 20 21:01 librecIoc.a lrwxrwxrwx. 1 root root 17 Jun 20 21:01 librecIoc.so -> librecIoc.so.3.14 -r-xr-xr-x. 1 root root 600493 Jun 20 21:01 librecIoc.so.3.14 -r--r--r--. 1 root root 55338 Jun 20 21:00 libregistryIoc.a lrwxrwxrwx. 1 root root 22 Jun 20 21:00 libregistryIoc.so -> libregistryIoc.so.3.14 -r-xr-xr-x. 1 root root 30822 Jun 20 21:00 libregistryIoc.so.3.14 -r--r--r--. 1 root root 434296 Jun 20 21:01 librsrvIoc.a lrwxrwxrwx. 1 root root 18 Jun 20 21:01 librsrvIoc.so -> librsrvIoc.so.3.14 -r-xr-xr-x. 1 root root 245350 Jun 20 21:01 librsrvIoc.so.3.14 -r--r--r--. 1 root root 860358 Jun 20 21:01 libsoftDevIoc.a lrwxrwxrwx. 1 root root 21 Jun 20 21:01 libsoftDevIoc.so -> libsoftDevIoc.so.3.14 -r-xr-xr-x. 1 root root 303003 Jun 20 21:01 libsoftDevIoc.so.3.14 -r--r--r--. 1 root root 42778 Jun 20 21:01 libtestDevIoc.a lrwxrwxrwx. 1 root root 21 Jun 20 21:01 libtestDevIoc.so -> libtestDevIoc.so.3.14 -r-xr-xr-x. 1 root root 29282 Jun 20 21:01 libtestDevIoc.so.3.14 But still with #make realclean realuninstall #make mkdir ../../../lib/linux-x86_64 Installing library ../../../lib/linux-x86_64/libpv.a make[3]: Leaving directory `/opt/epics/module/sncseq/src/pv/O.linux-x86_64' make[2]: Leaving directory `/opt/epics/module/sncseq/src/pv' make -C ./seq install make[2]: Entering directory `/opt/epics/module/sncseq/src/seq' perl ../../../../base-3.14.12.4/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../.. mkdir O.Common make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64 install make[3]: Entering directory `/opt/epics/module/sncseq/src/seq/O.linux-x86_64' Installing generic include file ../../../include/seqCom.h make[3]: *** No rule to make target `../../../lib/linux-x86_64/libiocsh.a', needed by `libseq.a'. Stop. make[3]: Leaving directory `/opt/epics/module/sncseq/src/seq/O.linux-x86_64' make[2]: *** [install.linux-x86_64] Error 2 make[2]: Leaving directory `/opt/epics/module/sncseq/src/seq' make[1]: *** [seq.install] Error 2 make[1]: Leaving directory `/opt/epics/module/sncseq/src' make: *** [src.install] Error 2 with best regards On Saturday, June 14, 2014 9:48 PM, Mark Rivers <[email protected]> wrote: Have you successfully built base-3.14.12.4 for the architecture you are building sncseq for? Send the output of: ls -l /opt/epics/base-3.14.12.4/lib/linux-x86_64 If that looks OK then send the complete output of: cd /opt/epics/modules/sncseq make realclean realuninstall make Mark ________________________________ From: Vikram Bhagat [[email protected]] Sent: Saturday, June 14, 2014 2:04 PM To: Mark Rivers; epics talk Subject: Re: sequencer installation Hi, From base folder $ pwd /opt/epics/base-3.14.12.4 and in sncseq/configure/RELEASE #EPICS_BASE=/home/phoebus/ANJ/epics/base/3-14-dev EPICS_BASE=/opt/epics/base-3.14.12.4 what is wrong with this setting? With Best Regards Vikram On Friday, June 13, 2014 7:41 PM, Mark Rivers <[email protected]> wrote: It looks to me like you have not correctly defined EPICS_BASE in sncseq/configure/RELEASE. Mark From: Vikram Bhagat [mailto:[email protected]] Sent: Friday, June 13, 2014 12:39 PM To: Mark Rivers; epics talk Subject: Re: sequencer installation I installed base3.14.12.4 but for installation of sequencer, i have below error make[1]: Leaving directory `/opt/epics/modules/sncseq/configure' make -C ./src install make[1]: Entering directory `/opt/epics/modules/sncseq/src' make -C ./pv install make[2]: Entering directory `/opt/epics/modules/sncseq/src/pv' make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64 install make[3]: Entering directory `/opt/epics/modules/sncseq/src/pv/O.linux-x86_64' make[3]: Nothing to be done for `install'. make[3]: Leaving directory `/opt/epics/modules/sncseq/src/pv/O.linux-x86_64' make[2]: Leaving directory `/opt/epics/modules/sncseq/src/pv' make -C ./seq install make[2]: Entering directory `/opt/epics/modules/sncseq/src/seq' make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64 install make[3]: Entering directory `/opt/epics/modules/sncseq/src/seq/O.linux-x86_64' make[3]: *** No rule to make target `../../../lib/linux-x86_64/libiocsh.a', needed by `libseq.a'. Stop. make[3]: Leaving directory `/opt/epics/modules/sncseq/src/seq/O.linux-x86_64' make[2]: *** [install.linux-x86_64] Error 2 make[2]: Leaving directory `/opt/epics/modules/sncseq/src/seq' make[1]: *** [seq.install] Error 2 make[1]: Leaving directory `/opt/epics/modules/sncseq/src' make: *** [src.install] Error 2 Please suggest me how to come out from this problem. With best Regards Vikram On Wednesday, June 4, 2014 10:40 PM, Mark Rivers <[email protected]<mailto:[email protected]>> wrote: I would suggest using 3.14.12.4 and see if you still have a problem. ________________________________ From: Vikram Bhagat [[email protected]<mailto:[email protected]>] Sent: Wednesday, June 04, 2014 3:14 PM To: Mark Rivers; epics talk Subject: Re: sequencer installation Dear Mark There nothing special to use EPICS3.15, i am installing in my system so just took latest. Vikram On Wednesday, June 4, 2014 10:09 PM, Mark Rivers <[email protected]<mailto:[email protected]>> wrote: You are using EPICS 3.15. Do you have a reason for using that? It is still not ready for production systems. Should you be using 3.14.12.4 instead? Mark ________________________________ From: [email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>> [[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>] on behalf of Vikram Bhagat [[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>] Sent: Wednesday, June 04, 2014 3:02 PM To: epics talk Subject: sequencer installation Hello, I am trying to install sequencer but could not build Below is the log an anyone guide me what is wrong with installation. [root@sarva-PC<mailto:root@sarva-PC><mailto:root@sarva-PC<mailto:root@sarva-PC>> sncseq]# make make -C ./configure install make[1]: Entering directory `/opt/epics/modules/sncseq/configure' make -C O.linux-x86_64 -f ../Makefile TOP=../.. T_A=linux-x86_64 install make[2]: Entering directory `/opt/epics/modules/sncseq/configure/O.linux-x86_64' perl -CSD /opt/epics/base/bin/linux-x86_64/convertRelease.pl checkRelease make[2]: Leaving directory `/opt/epics/modules/sncseq/configure/O.linux-x86_64' make[1]: Leaving directory `/opt/epics/modules/sncseq/configure' make -C ./src install make[1]: Entering directory `/opt/epics/modules/sncseq/src' make -C ./pv install make[2]: Entering directory `/opt/epics/modules/sncseq/src/pv' make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64 install make[3]: Entering directory `/opt/epics/modules/sncseq/src/pv/O.linux-x86_64' make[3]: *** No rule to make target `/opt/epics/base-3.15.0.1/include/shareLib.h', needed by `pvNew.o'. Stop. make[3]: Leaving directory `/opt/epics/modules/sncseq/src/pv/O.linux-x86_64' make[2]: *** [install.linux-x86_64] Error 2 make[2]: Leaving directory `/opt/epics/modules/sncseq/src/pv' make[1]: *** [pv.install] Error 2 make[1]: Leaving directory `/opt/epics/modules/sncseq/src' make: *** [src.install] Error 2 [root@sarva-PC<mailto:root@sarva-PC><mailto:root@sarva-PC<mailto:root@sarva-PC>> sncseq]# I set EPICS_BASE=/opt/epics/base in configure/RELEASE Thanks Vikram
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
