1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: measComp R1-1 released
To: EPICS Tech-Talk <[email protected]>
Date: Thu, 26 Jun 2014 21:06:21 +0000
Folks,
Release 1-1 of the measComp module is now available.
The major items from the release notes are:
* Added support for the new USB-CTR04/08 counter/timer modules. This includes support for the EPICS scaler record (similar to the Joerger VSC and SIS3820), and multi-channel scaler mode (similar to the SIS3820). This device can replace the SIS3820 in most applications for $429, which is less than 10% of the cost of the SIS3820.
* Added _RBV (readback) fields for pulse generator Period, Frequency, Width, and Delay since the requested value may not match the actual value due to hardware limitations.
* Add new demoSrc directory that contains a tutorial/demo on how to write a driver using asynPortDriver. The example is based on the USB-1608GX-2AO. It includes:
  o 6 versions of the demo driver source code, starting with a very simple 132 line driver that just does 2 analog output records, and ending with the full driver that is 1255 lines and has waveform digitizer and waveform generator support, etc.
  o A new iocMeasCompDemo directory with the various versions of the startup script.
  o New medm files (measCompDemoTop.adl, 1608G_V[1,2,3,4,5].adl).
  o New files in the documentation directory, measCompDriverTalk.pdf and measCompTutorial.pdf that were presented at an EPICS class on writing drivers based on asynPortDriver.
The home page for measComp is here:
http://cars.uchicago.edu/software/epics/measComp.html
The documentation is here:
http://cars.uchicago.edu/software/epics/measCompDoc.html
Cheers,
Prev: Re: Huber Unichiller 012-MPC support module? Florian Feldbauer
Next: What to do when device initialisation fails nick.rees
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Job Announcement: US ITER Instrumentation & Controls Group Leader - 1st of a kind fusion reactor, international partnership, management role Cherry, Steve J.
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
