1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: dxp R3-3 released
Date: Fri, 27 Jun 2014 22:44:49 +0000
Folks,
Release R3-3 of the synApps dxp module is now available.
These are the major items from the release notes:
- Changed Makefile to build with areaDetector 2-0, which has a different layout than previous versions of areaDetector.
- Fixed a bug in mapping modes on the xMAP and Mercury. The problem occurred when the final mapping buffer was just a few pixels and the dwell time per pixel was less than 5 ms. Under these conditions the final mapping buffer might not be read out, and the file saving plugins would not get the callbacks for the final buffer. After acquisition completes both mapping buffers (A and B) may need to be read out, but the previous code was only forcing 1 read, not 2. Changed code to force 2 calls to read the mapping buffers after acquisition completes.
The link to downloading the source code and pre-built binaries can be found here:
http://cars.uchicago.edu/software/epics/dxp
The documentation is here:
http://cars.uchicago.edu/software/epics/dxpDoc.html
Cheers,
Prev: mca R7-5 available Mark Rivers
Next: RE: What to do when device initialisation fails nick.rees
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Problems using devSnmp from NSCL Florian Feldbauer
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
