> I just see that this is not a problem with vxWorks 6.9 but with the
> Windows host build.
> Eric, have you tested your change with Windows?
That change was done in EPICS base 3.14.10 in 2008. We have certainly built a lot on Windows since then!
The question is what version of Visual Studio is Amit using? He did not tell us that in the original post. I have used Visual Studio 2008 and 2010 to compile base since 2008 and have not had this problem. I suspect that Amit is using a more recent version of Visual Studio?
Sent: Monday, July 21, 2014 3:15 AM
To: Mark Rivers; Eric Norum
Cc: [email protected]
Subject: Re: EPICS on VxWorks6.9
On 16.07.2014 20:40, Mark Rivers wrote:
>> The problem is
>> T * volatile * buffer;
>> in epicsRingPointer.h.
>> I am not sure if "volatile" really makes any sense here.I strongly suggest NOT removing the volatile keyword.
> In October 2008 we struggled with a very nasty bug in epicsRingPointer.h. The symptoms were:
> - Only failed on multi-processor systems
> - Only failed with recent versions of gcc with optimization enabled
> - Only failed 1 in 100,000 times
> Eric Norum fixed the problem. The changes included the following (comparison of epicsRingPointer.h from base 3.14.8.2 and 3.14.12.4)
> -private: // Data
> - int nextPush;
> - int nextPop;
> +private: /* Data */
> + volatile int nextPush;
> + volatile int nextPop;
> int size;
> - T **buffer;
> + T * volatile * buffer;
> So he added that volatile keyword, and it would need a lot of testing to prove it is not needed.
> Mark
In that case the volatile needs to be removed for the delete, because it
seems that the compiler thinks that there is no delete operator for
arrays of volatiles and implicitly converting volatile away is
considered impossible.
Windows host build.
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf Of Dirk Zimoch
> Sent: Wednesday, July 16, 2014 7:00 AM
> To: [email protected]
> Newer C++ compilers consider more and more things in EPICS errors. And
> maybe they are right.
> The problem is
> The other possibility is to cast away the "void" in the destructor.
> delete [ ] (T*) buffer;
> Or whatever the nicer C++ syntax is (probably using const_cast<T*>()?)
> Dirk
> On 16.07.2014 08:14, Amit Chauhan wrote:
>> Hi,
>> We are trying to put EPICS on VxWorks.
>> Various information related to our setup are:
>> EPICS base version : 3.14.12.4
>> VxWorks Version : 6.9
>> Workbench version : 3.3
>> Host Architecture : win32 on x86
>> Target Architecture: ppc-32
>> Target Board : MVME-5500 with PowerPC 7447 processor
>> On running the 'make' command, the EPICS build stops after a while with
>> an error.
>> *_Following is the output of the make command:_*
>> make -C ./configure install
>> make[1]: Entering directory `C:/EPICS/base-3-14-12-4/configure'
>> perl ../src/tools/makeMakefile.pl O.win32-x86 ../..
>> perl ../src/tools/makeMakefile.pl O.vxWorks-ppc32 ../..
>> perl -MExtUtils::Command -e mkpath O.Common
>> make -C O.win32-x86 -f ../Makefile TOP=../.. T_A=win32-x86 install
>> make[2]: Entering directory `C:/EPICS/base-3-14-12-4/configure/O.win32-x86'
>> make[2]: Nothing to be done for `install'.
>> make[2]: Leaving directory `C:/EPICS/base-3-14-12-4/configure/O.win32-x86'
>> make -C O.vxWorks-ppc32 -f ../Makefile TOP=../.. T_A=vxWorks-ppc32 install
>> `C:/EPICS/base-3-14-12-4/configure/O.vxWorks-ppc32'
>> make[1]: Leaving directory `C:/EPICS/base-3-14-12-4/configure'
>> make -C ./src install
>> make[1]: Entering directory `C:/EPICS/base-3-14-12-4/src'
>> make -C ./tools install
>> make[2]: Entering directory `C:/EPICS/base-3-14-12-4/src/tools'
>> perl ../../src/tools/makeMakefile.pl O.win32-x86 ../../..
>> perl ../../src/tools/makeMakefile.pl O.vxWorks-ppc32 ../../..
>> make -C O.win32-x86 -f ../Makefile TOP=../../.. T_A=win32-x86 install
>> make[3]: Entering directory `C:/EPICS/base-3-14-12-4/src/tools/O.win32-x86'
>> make[3]: Nothing to be done for `install'.
>> make[3]: Leaving directory `C:/EPICS/base-3-14-12-4/src/tools/O.win32-x86'
>> make -C O.vxWorks-ppc32 -f ../Makefile TOP=../../.. T_A=vxWorks-ppc32
>> install
>> `C:/EPICS/base-3-14-12-4/src/tools/O.vxWorks-ppc32'
>> make[2]: Leaving directory `C:/EPICS/base-3-14-12-4/src/tools'
>> make -C ./makeBaseApp install
>> make[2]: Entering directory `C:/EPICS/base-3-14-12-4/src/makeBaseApp'
>> perl C:\EPICS\base-3-14-12-4/bin/win32-x86/makeMakefile.pl O.win32-x86
>> `C:/EPICS/base-3-14-12-4/src/makeBaseApp/O.win32-x86'
>> install
>> `C:/EPICS/base-3-14-12-4/src/makeBaseApp/O.vxWorks-ppc32'
>> make[2]: Leaving directory `C:/EPICS/base-3-14-12-4/src/makeBaseApp'
>> make -C ./makeBaseExt install
>> make[2]: Entering directory `C:/EPICS/base-3-14-12-4/src/makeBaseExt'
>> `C:/EPICS/base-3-14-12-4/src/makeBaseExt/O.win32-x86'
>> install
>> `C:/EPICS/base-3-14-12-4/src/makeBaseExt/O.vxWorks-ppc32'
>> make[2]: Leaving directory `C:/EPICS/base-3-14-12-4/src/makeBaseExt'
>> make -C ./libCom install
>> make[2]: Entering directory `C:/EPICS/base-3-14-12-4/src/libCom'
>> make[3]: Entering directory `C:/EPICS/base-3-14-12-4/src/libCom/O.win32-x86'
>> perl ../../../src/libCom/misc/makeEpicsVersion.pl
>> ../../../configure/CONFIG_BASE_VERSION ../O.Common
>> Building epicsVersion.h from ../../../configure/CONFIG_BASE_VERSION
>> Found EPICS Version 3.14.12.4
>> "Installing generated generic include file
>> C:\EPICS\base-3-14-12-4/include/epicsVersion.h"
>> rc -l 0x409 -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32
>> -I../../../src/libCom/osi/os/default -I..
>> -I../../../src/libCom/bucketLib -I../../../src/libCom/ring
>> -I../../../src/libCom/calc -I../../../src/libCom/cvtFast
>> -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates
>> -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib
>> -I../../../src/libCom/env -I../../../src/libCom/error
>> -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList
>> -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh
>> -I../../../src/libCom/logClient -I../../../src/libCom/macLib
>> -I../../../src/libCom/misc -I../../../src/libCom/osi
>> -I../../../src/libCom/taskwd -I../../../src/libCom/timer
>> -I../../../src/libCom/tsDefs -IC:\EPICS\base-3-14-12-4/include/os/WIN32
>> -IC:\EPICS\base-3-14-12-4/include -fo Com.res ../Com.rc
>> cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE
>> /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT
>> -DEPICS_DLL_NO -I. -I..\\O.Common -I.
>> -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32
>> -I..\\..\\..\\src\\libCom\\osi\\os\\default -I..
>> -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring
>> -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast
>> -I..\\..\\..\\src\\libCom\\cppStd
>> -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf
>> -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env
>> -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr
>> -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash
>> -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient
>> -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc
>> -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd
>> -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs
>> -IC:\EPICS\base-3-14-12-4\\include\\os\\WIN32
>> ..\\..\\..\\src\\libCom\\bucketLib\\bucketLib.c
>> bucketLib.c
>> cl /nologo /EHsc /GR -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE
>> -DEPICS_DLL_NO /TP -I. -I..\\O.Common -I.
>> ..\\..\\..\\src\\libCom\\ring\\epicsRingPointer.cpp
>> ..\..\..\src\libCom\ring\epicsRingPointer.h(93) : *error C2664: 'delete'
>> : cannot convert parameter 1 from 'void *volatile * ' to 'void *'*
>> * Conversion loses qualifiers*
>> ..\..\..\src\libCom\ring\epicsRingPointer.cpp(82) : while compiling
>> class-template member function '__thiscall
>> epicsRingPointer<void>::~epicsRingPointer<void>(void)'
>> make[3]: Leaving directory `C:/EPICS/base-3-14-12-4/src/libCom/O.win32-x86'
>> make[2]: Leaving directory `C:/EPICS/base-3-14-12-4/src/libCom'
>> make[1]: Leaving directory `C:/EPICS/base-3-14-12-4/src'
>> */The following code is written in epicsRingPointer.h (line 93):/*
>> inline epicsRingPointer<T>:: ~epicsRingPointer( )
>> { delete [ ] buffer; }
>> If anyone can suggest us the solution to overcome this error it will be
>> of help to us.
>> Regards,
>> Amit Chauhan,
>> RRCAT, Indore
- RE: EPICS on VxWorks6.9 Amit Chauhan
- EPICS on VxWorks6.9 Amit Chauhan
- Re: EPICS on VxWorks6.9 Dirk Zimoch
- RE: EPICS on VxWorks6.9 Mark Rivers
Re: EPICS alarming on VAL != X Benjamin Franksen
Re: EPICS alarming on VAL != X Jameson Graef Rollins
<2014>
2025
<2014>
2025
