1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Building LabCA for MATLAB
To: [email protected]
Date: Mon, 4 Aug 2014 23:55:34 +0200
Hi tech-talk-team,
I'm sorry for my contacting you by an email, but I couldn't find a - understandable - solution for my problem (I'm student and not so familiar yet in programming):
My aim is to realize a labCA interface for my Matlab software to use the EPICS base package. The circumstances for me are: I have an 64bit Windows 7 operating system installed.
My steps so far:
  I have set up Cygwin64 on my laptop and I've installed the EPICS Base package (I'm not sure if shared libraries are already      included) by these  steps:
              - Install of cygwin with "gcc-g++", "make", "readline", "perl"
              - new folder C:\epics
              - change rights for use of this filder to "All Users"
              - depack baseR3.14.12.4.tar.gz by cygwin:
                    tar xvzf /cygdrive/c/YOUR_USER_NAME/Downloads/baseR3.14.12.4.tar.gz -C /cygdrive/c/epics/
                    cd /cygdrive/c/Program\ Files/epics/base-3.14.12.4/
                   make
I included "PATH" by C:\cygwin\bin" and "C:\epics\base-3.14.12.4\bin\cygwin-x86"
so far, so good.... (I did all these steps in cygwin 64 bit version.
Now I downloaded labca from your homepage and installed it in C:\labca
After the install, I changed the CONFIG and RELEASE-file in the labca\configure-folder:
 CONFIG: I added these lines by Windows Editor
                  -  MAKEFOR=MATLAB
                  -  CONFIG_USE_CTRLC=YES
and RELEASE:
                  - INSTALL_LOCATION_APP=C:\\labca
                  - EPICS_BASE=/cygdrive/c/epics/base-3-14-12-4
                  - MATLABDIR = C:\\Program\ Files\ \(x86\)\\MATLAB\\R2013aStudent
                  - EPICS_HOST_ARCH=cygwin-x86
                  - MATLIB_SUBDIR=win32/microsoft
After these changes I opened Cygwin again and entered
    $ cd /cygdrive/c/labca/
Finally I entered the command 'make' and got
make -C ./configure install
make[1]: Entering directory '/cygdrive/c/labca/configure'
make -C O.cygwin-x86 -f ../Makefile TOP=../.. T_A=cygwin-x86 install
make[2]: Entering directory '/cygdrive/c/labca/configure/O.cygwin-x86'
/cygdrive/c/epics/base-3-14-12-4/configure/RULES.Db:198: target 'C' doesn't match the target pattern
/cygdrive/c/epics/base-3-14-12-4/configure/RULES.Db:212: target 'C' doesn't match the target pattern
/cygdrive/c/epics/base-3-14-12-4/configure/RULES.Db:213: warning: overriding recipe for target 'C'
/cygdrive/c/epics/base-3-14-12-4/configure/RULES.Db:199: warning: ignoring old recipe for target 'C'
/cygdrive/c/epics/base-3-14-12-4/configure/RULES.Db:283: target 'C' doesn't match the target pattern
/cygdrive/c/epics/base-3-14-12-4/configure/RULES.Db:284: warning: overriding recipe for target 'C'
/cygdrive/c/epics/base-3-14-12-4/configure/RULES.Db:213: warning: ignoring old recipe for target 'C'
/cygdrive/c/epics/base-3-14-12-4/configure/RULES.Db:287: target 'C' doesn't match the target pattern
/cygdrive/c/epics/base-3-14-12-4/configure/RULES.Db:288: warning: overriding recipe for target 'C'
/cygdrive/c/epics/base-3-14-12-4/configure/RULES.Db:284: warning: ignoring old recipe for target 'C'
/cygdrive/c/epics/base-3-14-12-4/configure/RULES.Db:350: target 'C' doesn't match the target pattern
/cygdrive/c/epics/base-3-14-12-4/configure/RULES.Db:351: warning: overriding recipe for target 'C'
/cygdrive/c/epics/base-3-14-12-4/configure/RULES.Db:288: warning: ignoring old recipe for target 'C'
/cygdrive/c/epics/base-3-14-12-4/configure/RULES.Db:355: target 'C' doesn't match the target pattern
/cygdrive/c/epics/base-3-14-12-4/configure/RULES.Db:356: warning: overriding recipe for target 'C'
/cygdrive/c/epics/base-3-14-12-4/configure/RULES.Db:351: warning: ignoring old recipe for target 'C'
/cygdrive/c/epics/base-3-14-12-4/configure/RULES_JAVA:141: target 'C' doesn't match the target pattern
/cygdrive/c/epics/base-3-14-12-4/configure/RULES_JAVA:142: warning: overriding recipe for target 'C'
/cygdrive/c/epics/base-3-14-12-4/configure/RULES.Db:356: warning: ignoring old recipe for target 'C'
/cygdrive/c/epics/base-3-14-12-4/configure/RULES_JAVA:145: target 'C' doesn't match the target pattern
/cygdrive/c/epics/base-3-14-12-4/configure/RULES_JAVA:146: warning: overriding recipe for target 'C'
/cygdrive/c/epics/base-3-14-12-4/configure/RULES_JAVA:142: warning: ignoring old recipe for target 'C'
/cygdrive/c/epics/base-3-14-12-4/configure/RULES_FILE_TYPE:66: target 'C' doesn't match the target pattern
/cygdrive/c/epics/base-3-14-12-4/configure/RULES_FILE_TYPE:66: warning: overriding recipe for target 'C'
/cygdrive/c/epics/base-3-14-12-4/configure/RULES_JAVA:146: warning: ignoring old recipe for target 'C'
/cygdrive/c/epics/base-3-14-12-4/configure/RULES_FILE_TYPE:66: warning: ignoring old recipe for target 'C'
/cygdrive/c/epics/base-3-14-12-4/configure/RULES_BUILD:129: *** target pattern contains no '%'.  Schluss.
make[2]: Leaving directory '/cygdrive/c/labca/configure/O.cygwin-x86'
/cygdrive/c/epics/base-3-14-12-4/configure/RULES_ARCHS:63: recipe for target 'install.cygwin-x86' failed
make[1]: *** [install.cygwin-x86] Error 2
make[1]: Leaving directory '/cygdrive/c/labca/configure'
/cygdrive/c/epics/base-3-14-12-4/configure/RULES_DIRS:70: recipe for target 'configure.install' failed
make: *** [configure.install] Error 2
I've spent days in looking for a solution, but I could find it and I hope you can give me this answer how to realize the LabCA building.
Thank you so much for your support!
Best regards,
Nicolas
RE: Building LabCA for MATLAB Emmanuel Mayssat
Prev: Caen NDT1470 support? Brown, Garth
Next: Re: Recommended Control HWs for High Voltage Platform Silver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Building LabCA for MATLAB Emmanuel Mayssat
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
