1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: synApps
To: [email protected]
Date: Fri, 08 Aug 2014 19:56:27 +0900
You need the EPICS extension, msi, version 1-5 or higher in order to compile synApps. Please see
How to build synApps at the following site:
http://www.aps.anl.gov/bcda/synApps/synApps_5_7.html
The msi extensions is located at
http://www.aps.anl.gov/epics/extensions/msi/index.php
Han
On 08/08/2014 07:33 PM, priya tiwari wrote:
make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install
make[4]: Entering directory
`/home/srk/epics/synApps/synApps_5_3/support/vxStats/1-7-2e/vxStatsApp/Db/O.linux-x86'
Inflating database from ../vxStats-template.substitutions using local rule
msi -S../vxStats-template.substitutions > vxStats-template.db </dev/null
/bin/sh: msi: command not found
make[4]: *** [../O.Common/vxStats-template.db] Error 127
make[4]: Leaving directory
make[3]: *** [install.linux-x86] Error 2
make[3]: Leaving directory
`/home/srk/epics/synApps/synApps_5_3/support/vxStats/1-7-2e/vxStatsApp/Db'
make[2]: *** [Db.install] Error 2
make[2]: Leaving directory
`/home/srk/epics/synApps/synApps_5_3/support/vxStats/1-7-2e/vxStatsApp'
make[1]: *** [vxStatsApp.install] Error 2
make[1]: Leaving directory
`/home/srk/epics/synApps/synApps_5_3/support/vxStats/1-7-2e'
make: ***
[/home/srk/epics/synApps/synApps_5_3/support/vxStats/1-7-2e.install] Error 2
srk@localhost:~/epics/synApps/synApps_5_3/support/config$ :Error 127
bash: :Error: command not found...
Jeong Han Lee, Dr.rer.nat.
Accelerator Systems Division
Rare Isotope Science Project
Institute for Basic Science
Daejeon, South Korea
tel  : +82-42-878-8733
fax  : +82-42-878-8799
synApps priya tiwari
Prev: synApps priya tiwari
Next: Re: Problem linking Mclennan stepper motor libraries into x86 IOC app Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Help with building CSS using cs-studio-3.3.x Xinyu.Wu
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
