1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: synApps_5_7 build error on Windows 8.1 x64
To: "'Benjamin Franksen'" <[email protected]>, "[email protected]" <[email protected]>
Cc: Alireza Panna <[email protected]>
Date: Fri, 29 Aug 2014 14:27:55 +0000
I just tried building the following versions of the sequencer on windows-x64 (Windows 7, Visual Studio 2010, GNUWin32 make).
seq-2.1.10
seq-2.1.13
seq-2.2.0.1
2.1.10 built with no errors.
2.1.13 did not have the error with lemon.exe that was the subject of this thread.  Here is the output when lemon.exe is being used:
make -C O.windows-x64 -f ../Makefile TOP=../../.. T_A=windows-x64 install
make[3]: Entering directory `J:/epics/devel/seq-2-1-13/src/snc/O.windows-x64'
..\\..\\..\\bin\\windows-x64\\lemon.exe o=. ../snl.lem
3 parsing conflicts.
re2c.exe -s -b -o lexer.c ../snl.re
make[3]: Leaving directory `J:/epics/devel/seq-2-1-13/src/snc/O.windows-x64'
However, 2.1.13 did fail much later in the build with the following error:
"converting userfuncEf.i"
../../../bin/windows-x64/snc.exe   +m -i  userfuncEf.i -o userfuncEf.c.tmp
perl -MExtUtils::Command -e mv userfuncEf.c.tmp userfuncEf.c
cl -c             /favor:blend   /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common
-I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include -IH:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IH:\\epics\\base-3.14.12.4\\include       userfuncEf.c
userfuncEf.c
userfuncEf.c(13) : error C2016: C requires that a struct or union has at least one member
../userfuncEf.st(26) : error C2059: syntax error : '}'
make[3]: *** [userfuncEf.obj] Error 2
make[3]: Leaving directory `J:/epics/devel/seq-2-1-13/test/validate/O.windows-x64'
make[2]: *** [install.windows-x64] Error 2
make[2]: Leaving directory `J:/epics/devel/seq-2-1-13/test/validate'
make[1]: *** [validate.install] Error 2
make[1]: Leaving directory `J:/epics/devel/seq-2-1-13/test'
make: *** [test.install] Error 2
2.2.0.1 failed very early in the build with the following error:
"Installing generic include file ../../../include/seq_prim_types.h"
-I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include -IH:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IH:\\epics\\base-3.14.12.4\\include       ..\\seq_main.c
seq_main.c
..\seq_main.c(282) : error C2124: divide or mod by zero
make[3]: *** [seq_main.obj] Error 2
make[3]: Leaving directory `J:/epics/devel/seq-2-2-0-1/src/seq/O.windows-x64'
make[2]: Leaving directory `J:/epics/devel/seq-2-2-0-1/src/seq'
make[1]: *** [seq.install] Error 2
make[1]: Leaving directory `J:/epics/devel/seq-2-2-0-1/src'
make: *** [src.install] Error 2
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Benjamin Franksen
Sent: Friday, August 29, 2014 4:56 AM
To: [email protected]
Cc: Alireza Panna
Subject: Re: synApps_5_7 build error on Windows 8.1 x64
On Thursday 28 August 2014 16:54:00 Alireza Panna wrote:
> Hello all,
> I am having trouble building the sequencer module. base compiles fine
> under windows-x64, however when i try to build the sequencer module
> in synApps-5-7, I get the following error:
> make[3]: Entering directory `C:/Epics/support/seq-2-1-13/src/snc'
> install make[4]: Entering directory
> `C:/Epics/support/seq-2-1-13/src/snc/O.windows-x64'
> make[4]: Leaving directory
>  /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MD     -I.
> -I..\\O.C
> ommon -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include
> -IC:\\Epic
> s\\base\\include\\os\\WIN32 -IC:\\Epics\\base\\include       lexer.c
> lexer.c
> ../snl.re(16) : fatal error C1083: Cannot open include file: 'snl.h':
> No such fi
> le or directory
> make[4]: *** [lexer.obj] Error 2
> make[3]: *** [install.windows-x64] Error 2
> make[3]: Leaving directory `C:/Epics/support/seq-2-1-13/src/snc'
> make[2]: *** [snc.install] Error 2
> make[2]: Leaving directory `C:/Epics/support/seq-2-1-13/src'
> make[1]: *** [src.install] Error 2
> make[1]: Leaving directory `C:/Epics/support/seq-2-1-13'
> make: *** [C:/Epics/support/seq-2-1-13.install] Error 2
> Before this error occurs, I get a pop up saying lemon.exe has stopped
> working.
Hm, that sounds like the bundled version of lemon crashes (or otherwise
misbehaves) when compiled as a win64 executable. In this case it would
not generate snl.h which is what the error message says.
To clarify this, please
> cd C:/Epics/support/seq-2-1-13/src/snc/O.windows-x64
> make clean
and then
It should say "3 parsing conflicts." and there should now exist files
named snl.c, snl.h, and snl.out in this directory. If not (or if one of
these files is empty), then lemon is broken on win64 and I will see
whether the upstream version has a fix for the problem.
Cheers
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Re: synApps_5_7 build error on Windows 8.1 x64 Alireza Panna
Re: synApps_5_7 build error on Windows 8.1 x64 Benjamin Franksen
Prev: Open position at PSI Dirk Zimoch
Next: Re: synApps_5_7 build error on Windows 8.1 x64 Alireza Panna
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: synApps_5_7 build error on Windows 8.1 x64 Benjamin Franksen
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
