So when trying to run those command on the Linux side, this is what it says: [Vlad@Epics ~]$ /opt/Client/bin/linux-x86_64/caExample EpicsHost:ai1 CA.Client.Exception...............................................
Warning: "User specified timeout on IO operation expired" Context: "ca_pend_io failure" Source File: ../caExample.c line 20 Current Time: Tue Sep 02 2014 09:41:25.385035869
.................................................................. CA.Client.Exception............................................... Warning: "Virtual circuit disconnect"
Context: "ca_get failure" Source File: ../caExample.c line 21 Current Time: Tue Sep 02 2014 09:41:25.385503594 ..................................................................
CA.Client.Exception............................................... Warning: "User specified timeout on IO operation expired" Context: "ca_pend_io failure" Source File: ../caExample.c line 22
Current Time: Tue Sep 02 2014 09:41:30.385627321 .................................................................. EpicsHost:ai1 0.000000 [Vlad@Epics ~]$ caget EpicsHost:ai1
Channel connect timed out: 'EpicsHost:ai1' not found. [Vlad@Epics ~]$ caput EpicsHost:ai1 No value specified. ('caput -h' for help.) [Vlad@Epics ~]$ caput EpicsHost:ai1 2
Channel connect timed out: 'EpicsHost:ai1' not found. [Vlad@Epics ~]$ The PCs can communicate, when I ping the Linux one (the one I am trying to get to read the values from Windows) from Windows, it appears a connection is established.
----------------------------------------------------------------------------- Kind RegardsRusu Vlad Andrei T: (+004)0755.052.954
A: Calea Ferentari 16 Bl.124A Ap.5 Sector 5, Bucharest, Romania 2014-09-02 10:26 GMT+03:00 Ralph Lange <[email protected]>:
ANJ, 17 Dec 2015 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
