1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: about caPutLog
To: EPICS Tech-Talk <[email protected]>
Date: Tue, 02 Sep 2014 13:00:15 +0200
On 02/09/2014 11:24, Benjamin Franksen wrote:
I am forwarding this issue to tech-talk. Maybe someone there has an idea? The
attached picture shows the messages from the IOC.
Is the loopback interface configured? Is it up? (ifconfig)
Is the log server running? Is it listening on the right port? (ps / netstat)
Good luck,
~Ralph
Am Dienstag, 2. September 2014, 12:35:08 schrieben Sie:
Hi, Ben,
        Thank you for your reply.
        It seems it's not related to "firewall". I've disabled the firewall,
but the error still exsited.
I even enabled the firewall and open the port 7011 as "/sbin/iptables -I
INPUT -p tcp --dport 7011 -j ACCEPT", it still didn't work.
        My soft IOC server and client is on the same Linux/PC, is it OK?
zhaozhuo
-----原始邮件-----
Sent: Monday, September 01, 2014 2:55 PM
To: Zhao Zhuo
On Friday 29 August 2014 17:12:48 you wrote:
Hi, Ben Franksen,
I’m trying to run CaPutLog on my RedHat Linux PC, but it showed the
following error when I run the "st.cmd”. Do you know what’s wrong
with it?
The log client on the IOC cannot connect to the log server. The error
message clearly says why: "Connection refused". This is a question of
your system's setup. One reason could be that you have a firewall
running on your machine ("localhost"). Try configuring it to allow the
caPutLog port (7011 by default).
Cheers
Ben
Re: about caPutLog Benjamin Franksen
Prev: Re: about caPutLog Benjamin Franksen
Next: RE: stream device get started? Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: asyn record priya tiwari
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
