1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: motorApp R6.8 Mclennan PM600 opposite limit datum search mode on linux-arm
To: [email protected]
Date: Tue, 02 Sep 2014 10:59:44 -1000
On 09/01/14 03:55, Mark Rivers wrote:
Hi Peter,
I think the problem is that the motor record should ignore both soft
limits and hard limits during a homing sequence.  Soft limit
violations are expected because the controller does not yet know
where the motor is, and hard limits are also to be expected because
sometimes the homing operation involves hitting the limit switch, as
in your case.
I have had problems with the motor record stopping a motor when a
soft limit is exceeding during a homing operation too, but I believe
that has been fixed in a recent release.
Hi Mark,
I have one problem here: in my book the term "hard limit" means that
you can't physically move past that point without breaking something,
it is a physical end stop. (I have heard of that happening. That
particular telescope was out of commission for several weeks)
Datum switches should be a reasonable distance away from soft limits,
and hard limits should be further away from the datum switches than
that.
Obviously, circular mechanisms may or may not have these limitations,
but linear ones always do.
Maren
RE: motorApp R6.8 Mclennan PM600 opposite limit datum search mode on linux-arm Mark Rivers
motorApp R6.8 Mclennan PM600 opposite limit datum search mode on linux-arm Peter Linardakis
Prev: RE: stream device get started? Mark Rivers
Next: RE: motorApp R6.8 Mclennan PM600 opposite limit datum search mode on linux-arm Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: motorApp R6.8 Mclennan PM600 opposite limit datum search mode on linux-arm D'Ewart, J. Mitch
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
