1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: asyn record
To: "'priya tiwari'" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 3 Sep 2014 14:37:02 +0000
> How to install driver for NI USB-SH ,GPIB to USB instrument in FEDORA 19.and
You will need to read the documentation for the NI USB-HS to determine how to use it under Linux.  Although the USB-HS says it supports Linux, I could not find any information on installing it under Linux on this page:
http://search.ni.com/nisearch/app/main/p/ap/tech/lang/en/pg/1/sn/catnav:pm/fil/AND(nilanguage:en,phwebnt:5340,nicontenttype:productmanual,nidocstatus:current)/
You may be able to use the VXI-11 driver if they make a Linux device that looks like VXI-11, but if not you might need to write an asyn port driver.
> How to detect instrument in VDCT?
That is not what VDCT does.  You need a driver (preferably based on asyn) that records can then talk to using StreamDevice or other modules.
From: [email protected] [mailto:[email protected]] On Behalf Of priya tiwari
Sent: Wednesday, September 03, 2014 5:29 AM
To: [email protected]
Subject: asyn record
Hello
I am learning asyn module from release notes then i have seen more fields in release notes(asyn record:  Release 4-23) but not saw in VDCT asyn record like that : sock for socket,AINP,BINP,PCNCT
            then how can we add fields in record?
and my 2nd question is How to install driver for NI USB-SH ,GPIB to USB instrument in FEDORA 19.and How to detect instrument in VDCT?
please explain me I am beginner in EPICS. please help me...
  Thanks in advance.........................
asyn record priya tiwari
Prev: Re: Processing a record a in loop Rod Nussbaumer
Next: Re: Processing a record a in loop David Michel
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: asyn record Mooney, Tim M.
Next: Processing a record a in loop David Michel
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
