1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: BEAST configuration
To: Florian Feldbauer <[email protected]>
Date: Fri, 5 Sep 2014 13:47:18 +0000
Hi:
I've submitted an updated AlarmConfigurationSchema.xsd to the source repository, https://github.com/ControlSystemStudio/cs-studio/blob/557185964819bea6cb07d64252d91c7b0526bf28/applications/plugins/org.csstudio.alarm.beast.configtool/AlarmConfigurationSchema.xsd
and made the example a little longer, https://github.com/ControlSystemStudio/cs-studio/blob/557185964819bea6cb07d64252d91c7b0526bf28/applications/plugins/org.csstudio.alarm.beast.configtool/AnnunciatorDemoConfig.xml
-Kay
On Sep 5, 2014, at 9:04 AM, "Kasemir, Kay" <[email protected]> wrote:
> You're right that the XML format is not documented in detail beyond some basic schema file, https://github.com/ControlSystemStudio/cs-studio/blob/master/applications/plugins/org.csstudio.alarm.beast.configtool/AlarmConfigurationSchema.xsd.
> That schema does not include the <automated_action>, which was added to support the ITER-provided alarm notifier.
BEAST configuration Florian Feldbauer
Re: BEAST configuration Kasemir, Kay
Prev: Re: Processing a record a in loop David Michel
Next: Re: Processing a record a in loop David Michel
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: BEAST configuration Kasemir, Kay
Next: Modbus TCP/IP "PSH" Command Tobin Weber
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
