1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: areaDetector 1.9.1 "dyld: Symbol not found" on Darwin
To: Andrew Johnson <[email protected]>, [email protected]
Date: Fri, 05 Sep 2014 17:30:05 -0500
On 9/5/14, 5:06 PM, Andrew Johnson wrote:
> Running that symbol through c++filt on a Mac gives the following
> unmangled name:
> woz$ c++filt __ZNSs4_Rep20_S_empty_rep_storageE
> std::string::_Rep::_S_empty_rep_storage
> Doing a web search on that implies that you need to link against
> libstdc++, so try adding this to the Makefile that builds
> simDetectorApp:
>     OP_SYS_LDLIBS += -lstdc++
Hi, Andrew.
Thanks for the suggestion.  Unfortunately, no dice; it still aborts.
Any other ideas?
Thanks!
Lewis
Re: areaDetector 1.9.1 "dyld: Symbol not found" on Darwin Andrew Johnson
areaDetector 1.9.1 "dyld: Symbol not found" on Darwin J. Lewis Muir
Prev: Re: areaDetector 1.9.1 "dyld: Symbol not found" on Darwin Andrew Johnson
Next: Re: areaDetector 1.9.1 "dyld: Symbol not found" on Darwin Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
