1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: msi missing when isntalling synApps
To: Vlad Andrei Rusu <[email protected]>
Date: Thu, 11 Sep 2014 13:43:19 +0000
I think you need to add the extensions/bin/linux-x86_64 directory in your PATH.
Sent from my iPhone
On Sep 11, 2014, at 8:40 AM, "Vlad Andrei Rusu" <[email protected]<mailto:[email protected]>> wrote:
Hello once again
We decided to install synApps on Linux and once again, some errors.
I am getting the following error when trying to "make" synApps, I have downlaoded msi, put it extensions/src and 'make' src folder. I also used 'make release' in synApps/support/;
msi   -I. -I.. -I../O.Common -I../../../db -I/opt/epics/base-3.14.12.3/db ../ioc.template > ioc.tmp
/bin/sh: msi: command not found
make[4]: *** [../O.Common/ioc.db] Error 127
make[4]: Leaving directory `/opt/synApps_5_7/support/devIocStats-3-1-7/iocAdmin/Db/O.linux-x86_64'
make[3]: *** [install.linux-x86_64] Error 2
make[3]: Leaving directory `/opt/synApps_5_7/support/devIocStats-3-1-7/iocAdmin/Db'
make[2]: *** [Db.install] Error 2
make[2]: Leaving directory `/opt/synApps_5_7/support/devIocStats-3-1-7/iocAdmin'
make[1]: *** [iocAdmin.install] Error 2
make[1]: Leaving directory `/opt/synApps_5_7/support/devIocStats-3-1-7'
make: *** [/opt/synApps_5_7/support/devIocStats-3-1-7.install] Error 2
Thank you once again!
Kind Regards
Rusu Vlad Andrei
T: (+004)0755.052.954
E: [email protected]<mailto:[email protected]>
A: Calea Ferentari 16 Bl.124A Ap.5 Sector 5, Bucharest, Romania
msi missing when isntalling synApps Vlad Andrei Rusu
Prev: msi missing when isntalling synApps Vlad Andrei Rusu
Next: RE: Keithley 2400 communication Mooney, Tim M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: msi missing when isntalling synApps Allison, Stephanie
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
