1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Sequencer 2.2.0
To: "Mooney, Tim M." <[email protected]>
Date: Mon, 15 Sep 2014 21:41:06 +0200
Am Montag, 15. September 2014, 15:42:49 schrieb Mooney, Tim M.:
> I'm fine with all of this.  I think all my stuff is compatible with both 2.1
> and 2.2, but I haven't used 2.2 yet because I haven't gotten it to run on
> vxWorks.
Thanks Tim
(I have fixed the problem you mentioned: I forgot to rename a macro when
moving header file stuff from snc to the seq library. I wonder why this fails
only on VxWorks. Will make a new release with the fix when I implemented the
stuff I proposed here.)
Have you considered what I wrote regarding the C API compatibility:
> the C API. In fact, I am thinking about fixing those incompatibilities I
> already introduced, namely those concerning the added timeout parameter for
> seq_pvGet and seq_pvPut functions, by adding new C functions seq_pvGetTmo
> and seq_pvPutTmo.
This would mean you don't need conditional compilation in escaped C code --
but instead you would have to revert the changes you already made...
Cheers
Ben
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
RE: Sequencer 2.2.0 Mooney, Tim M.
Sequencer 2.2.0 Benjamin Franksen
Re: Sequencer 2.2.0 Benjamin Franksen
Prev: EPICS vs. Firewalls Eric Norum
Next: Re: EPICS vs. Firewalls Konrad, Martin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Sequencer 2.2.0 Benjamin Franksen
Next: RE: Sequencer 2.2.0 Mooney, Tim M.
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
