1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Keithley 2400 communication
To: priya tiwari <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 15 Sep 2014 21:19:29 +0000
Hi Priya,
Another option for this series of instruments is to use Keithley’s Test Script Builder to define your own commands. You could define a function that set those parameters, then call that function with streamdevice. I’ve found it relatively easy to use, though maybe too much of a learning curve if this is the most complicated thing you want to do.
Garth
From: [email protected] [mailto:[email protected]] On Behalf Of priya tiwari
Sent: Thursday, September 11, 2014 12:20 AM
To: [email protected]
Subject: Keithley 2400 communication
Hello,
        I am trying communication with KEITHLEY 2400 on serial port(RS-232).I sent command "*IDN?" it has performed very well and i got the output.
i want to reset the device and the commands are
*RST
:SOUR:FUNC VOLT
:SOUR:VOLT:MODE FIX
:SOUR:VOLT:RANG 20
:SOUR:VOLT:LEV 10
:OUTP ON
:READ?
now,How to write program in VDCT for performing all commands sequentially.Actually i have no idea about this.please help me....
Q.2: How to send commands to device  at run time in VDCT?
what is the format of
caput? on that time
Thanks in advance
Keithley 2400 communication priya tiwari
Prev: RE: Sequencer 2.2.0 Mooney, Tim M.
Next: Re: EPICS vs. Firewalls J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Keithley 2400 communication Mooney, Tim M.
Next: msi missing when isntalling synApps Vlad Andrei Rusu
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
