1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Asyn
Date: Thu, 18 Sep 2014 11:27:33 +0530
Thanks Martin L.Smith
On Wed, Sep 17, 2014 at 10:34 PM, Martin L. Smith <[email protected]> wrote:
I do this now using a scalcout and stringout records as such:
record(stringout,"$(P)ReadDioIn") {
        field(DESC,"Read DIO Input Command")
        field(DTYP,"Soft Channel")
        field(UDF,"0")
        field(VAL,"/DIO/read")
record(scalcout,"$(P)DioIn") {
        field(DESC,"Read DIO Inputs")
        field(CALC,"PRINTF('%s',AA)")
        field(INAA,"$(P)ReadDioIn.VAL NPP NMS")
        field(OUT,"$(P)DIO.AOUT PP NMS")
        field(SCAN,"2 second")
In this example every 2 seconds the scalcout processes and sends the string
/DIO/read to an asyn record AOUT field ($(P)DIO.AOUT) with a PP link which
causes the asyn record to process. So the string to send is in the stringout
record and the scalcout just formats the string.
Marty
On 09/17/2014 11:54 AM, priya tiwari wrote:
Actually i am just trying,it was not correct. but i want  give command in string
format from one record to AOUT field of asyn record.
On Wed, Sep 17, 2014 at 5:54 PM, Mark Rivers <[email protected]
<mailto:[email protected].edu>> wrote:
    Did you try connecting the OUT field of the sCalcout record to the AOUT
    field of the asyn record, using the PP attribute?
    From: [email protected] <mailto:tech-talk-bounces@aps.anl.gov>
    [[email protected] <mailto:tech-talk-bounces@aps.anl.gov>] on
    behalf of priya tiwari [[email protected]
    <mailto:tiwaripriya013@gmail.com>]
    Sent: Wednesday, September 17, 2014 6:12 AM
    To: [email protected] <mailto:[email protected]>
    Subject: Asyn
    Hello,
                I put the command such as *IDN?\n in INP field of waveform
    record and i want to retrieve this command in AOUT field of ASYN record.How
    to link it plz give suggestions...
    i am trying like this but it is wrong plz give me actual solution. I am
    attaching snapshot.
Asyn priya tiwari
RE: Asyn Mark Rivers
Re: Asyn priya tiwari
Re: Asyn Martin L. Smith
Prev: Sequencer web search lists out-dated sites Benjamin Franksen
Next: CSS Basic EPICS help crashing in Ubuntu bohmm
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Asyn Martin L. Smith
Next: Re: Asyn Dirk Zimoch
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
