1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: IOC server on windows or access a PV
To: [email protected]
Cc: [email protected]
Date: Fri, 03 Oct 2014 09:31:08 +0200
Dear Xiaoquiang,
Thanks for the information.
What is important to me is also to have a proper timestamp for the PVs and I an not very confident on the windows machine. If I install a portable channel access server, the timestamps of the PVs I serve there will be taken from the windows machine; am I right? If I have the server in other computer the timestamp of the uploaded PV will be given by that other server, not the "caput" operation I run in the windows; isn't it?
Best regards,
Zunbeltz
og., 2014.eko urrren 02a 22:13(e)an, Xiaoqiang Wang igorleak idatzi zuen:
There is a 3rd choice: create the PV in portable channel access server.
If your calculation code can be invoked with Python, be it a C extension or separate program (using subprocess module).
This can be easy to write using PCASpy[1] extension.
Best
Xiaoqiang
[1] https://pypi.python.org/pypi/pcaspy
On 02 Oct 2014, at 21:48, zunbeltz <[email protected]> wrote:
Dear all,
We need to pass some values, calculated from photographs, to the EPICS network from a windows machine.
Is it easy to install an IOC server in a windows machine?
If not, our idea is to create the PVs in an already running IOC server (on linux), and use caput tool (from the EPICS Extensions http://aps.anl.gov/epics/distributions/win32/index.php) to update the values.
Is it possible to create an  PV that is not associated with any hardware in a IOC server? Is it enough to add a record in the ioc.db file?
Thanks in advance for your help.
Zunbeltz
Dr. Zunbeltz Izaola
Accelerator Physics Group
ESS-Bilbao
Dr. Zunbeltz Izaola
ESS-Bilbao
Re: IOC server on windows or access a PV Xiaoqiang Wang
IOC server on windows or access a PV zunbeltz
Prev: Re: IOC server on windows or access a PV zunbeltz
Next: Re: IOC server on windows or access a PV zunbeltz
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: IOC server on windows or access a PV Xiaoqiang Wang
Next: Re: IOC server on windows or access a PV Xiaoqiang Wang
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
