1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [EPICS] Support for Staged Installs ?
Date: Sun, 05 Oct 2014 15:08:36 +0200
On October 5, 2014 1:39:31 PM CEST, Pavel Maslov <[email protected]> wrote:
Yeah, but what it does is it copies the tarball to INSTALL_LOCATION and starts build from there (which I don't need).
What I meant if it is possible to build from current directory, so that after the build you can manually (or using a script, make install, etc) put everything to INSTALL_LOCATION, and all the libraries and IOCs linked to them will not be broken.
Pavel Maslov, MS
On Sun, Oct 5, 2014 at 1:28 PM, Ralph Lange <[email protected]> wrote:
On October 5, 2014 12:11:15 PM CEST, Pavel Maslov <[email protected]> wrote:
Hi Andrew, all :
I am curious, does EPICS have support for staged installs [1] ?
Pavel Maslov, MS
Hi Pavel,
Try setting INSTALL_LOCATION.
NB: Obviously the Application Developer's Guide has a full chapter about the build system, explaining all available options in detail.
Cheers,
~Ralph
Pavel,
I don't know what kind of build system you are using, but setting INSTALL_LOCATION inside a make based build of a standard EPICS application does exactly what you describe. It builds locally and installs into the selected location (instead of TOP).
Are you using the make rules from EPICS Base?
Cheers,
~Ralph
Re: [EPICS] Support for Staged Installs ? Michael Davidsaver
[EPICS] Support for Staged Installs ? Pavel Maslov
Re: [EPICS] Support for Staged Installs ? Ralph Lange
Re: [EPICS] Support for Staged Installs ? Pavel Maslov
Prev: Re: [EPICS] Support for Staged Installs ? Pavel Maslov
Next: Re: [EPICS] Support for Staged Installs ? Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
