1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: histogram record and CSS XY Graph
Cc: "<[email protected]>" <[email protected]>
Date: Mon, 13 Oct 2014 15:45:54 +0000
Hi:
Just as you produce the data for the "Y" axis on the IOC in a histogram record, you might want to generate the data for the "X" axis in a record on the IOC as well.
Then configure the XY Graph widget to show those X and Y records.
To generate arbitrary "X" waveforms on the IOC, you may be able to use a "compress" record fed by a calc that counts from your desired start to end value, but otherwise I've used a genSub/aSub record for that.
Kay
On Oct 13, 2014, at 9:48 AM, "[email protected]" <[email protected]>
 wrote:
> Hi,
> I'm using a 'histogram' record to store some values:
> record(histogram,"$(P):noisefloor") {
>   field(DTYP,"$(D)")
>   field(DESC,"LTC2499 noise floor")
>   field(SCAN,"1 second")
>   field(SVL,"$(P):microvolt:CH0")
>   field(ULIM,20)
>   field(LLIM,-20)
>   field(NELM,100)
> as you can see number of bin is 100 and values are from -20 to 20;
> I'm able to create a histogram on CSS starting from XY Graph widget, but
> X axis reports values from 0 to 100. Is there a script in order to display
> values from -20 to 20 ?
> If I set 'Minumum' and 'Maximum' properties of "Primary X Axis" to -20 and
> 20 the graph is empty because values are plotted by histogram index and not by histogram value... (e.g. value 0 -> position 50)
> Thanks in advance,
> Gennaro
> Gennaro Tortone
> INFN Napoli
> Italy
> tel: +39 81 676169
> "Computer Science is no more about computers
>    than astronomy is about telescopes."
>    - Edsger Dijkstra
Re: histogram record and CSS XY Graph [email protected]
Prev: histogram record and CSS XY Graph [email protected]
Next: Re: histogram record and CSS XY Graph [email protected]
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
