1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: could it possible to get pv from another subnet?
To: HaveF <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 14 Oct 2014 12:48:05 +0000
I understand now, the CA client and CA server are on separate non-routeable subnets.  In that case I am not sure how to do it, though it seems like it could be done with port forwarding.  Router A could forward packets on a particular port (e.g. 15605) to port 5065 on the CAS machine.  Then the camonitor machine would need to change the ports it uses for CA to those new ports.
From: [email protected] [[email protected]] on behalf of HaveF [[email protected]]
Sent: Tuesday, October 14, 2014 2:45 AM
To: [email protected]
Subject: could it possible to get pv from another subnet?
Hi, all,
My network’s topology is like this:
              router A                          router B
           | 202.201.1.4 |                   | 202.201.1.5 |
       | 192.168.1.200 |                     | 192.168.1.100 |
       |   CAS         |                     |   camonitor   |
Could it possible to get pv from another subnet?
Could it possible to Set the CAS’s EPICS_CA_ADDR_LIST to 202.201.1.5,
and then configure router B, map the port 5065 to 192.168.1.255:5065<http://192.168.1.255:5065>?
or I have to replan the whole net and use layer 3 switch to
connect the subset?
                    |    layer 3 switch            |
       | 192.168.1.200 |                     | 192.168.2.100 |
       |   CAS         |                     |   camonitor   |
Thanks for reading.
Sincerely,
HaveF
RE: could it possible to get pv from another subnet? Mark S. Engbretson
could it possible to get pv from another subnet? HaveF
Prev: Re: could it possible to get pv from another subnet? Ryan Pierce
Next: RE: could it possible to get pv from another subnet? Mark S. Engbretson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: could it possible to get pv from another subnet? Andrew Johnson
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
