1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: webopi -- http status 404 error
To: "Kasemir, Kay" <[email protected]>
Date: Thu, 16 Oct 2014 16:49:29 -0400
Hello Kay,
Thank you for the quick response.  Sorry for the wrong screen shot.  I used the link
http://192.168.2.57:8080/apps/webopi
and got the same error.
Tomcat did unpack the webopi.war into apps#webopi directory.  I even removed the apps#webopi directory and found that if I try to access the url, the apps#webopi directory will be created.
I checked the log files and found that it complains can't find file:
java.io.FileNotFoundException: /usr/share/tomcat7/css_rap.ini (No such file or directory)
After copy the css_rap.ini into the /usr/share/tomcat7, the error message disappeared.  But the http status 404 error are still there (attached snapshot is after I copied the css_rap.ini).
I have attached the logs file and hope you can find something wrong.
Your kind help is appreciated.
- Tom
> From: [email protected]
> To: [email protected]
> CC: [email protected]
> Subject: Re: webopi -- http status 404 error
> Date: Thu, 16 Oct 2014 20:01:09 +0000
> On Oct 16, 2014, at 2:00 PM, Tom Smart <[email protected]<mailto:[email protected]>>
> wrote:
> 3. chown tomcat7.tomcat7 /var/lib/tomcat7/webapps/apps#webopi.war
> And when I used the following url
> or
> http://localhost:8080/app/webopi
> The screenshot showed "../app/.." as well, but you copied it into webapps/apps#webopi.war, so the link must also use "apps/webopi".
> Did tomcat unpack the webopi.war file into a webopi/ directory?
> Check the tomcat/logs/* files for error messages.
> > My java version is "1.6.0_32".
> I think you need Java 7.
> -Kay
Oct 16, 2014 12:19:40 PM org.apache.catalina.startup.HostConfig deployWAR
INFO: Deploying web application archive /var/lib/tomcat7/webapps/apps#webopi.war
Oct 16, 2014 12:19:43 PM org.csstudio.rap.core.preferences.ServerPreferenceNode load
WARNING: System property org.csstudio.rap.preference is not set, try user.home.
SEVERE: Server Side Preference loading failed.
	at java.io.FileInputStream.open(Native Method)
	at java.io.FileInputStream.<init>(FileInputStream.java:140)
	at java.io.FileInputStream.<init>(FileInputStream.java:96)
	at org.csstudio.rap.core.preferences.ServerPreferenceNode.loadProperties(ServerPreferenceNode.java:436)
	at org.csstudio.rap.core.preferences.ServerPreferenceNode.load(ServerPreferenceNode.java:419)
	at org.csstudio.rap.core.preferences.ServerPreferenceNode.<init>(ServerPreferenceNode.java:84)
	at org.csstudio.rap.core.preferences.ServerPreferenceFactory.create(ServerPreferenceFactory.java:9)
	at org.eclipse.core.internal.preferences.PreferenceServiceRegistryHelper.createNode(PreferenceServiceRegistryHelper.java:190)
	at org.eclipse.core.internal.preferences.PreferencesService.createNode(PreferencesService.java:387)
	at org.eclipse.core.internal.preferences.RootPreferences.getChild(RootPreferences.java:63)
	at org.eclipse.core.internal.preferences.RootPreferences.getNode(RootPreferences.java:101)
	at org.eclipse.core.internal.preferences.RootPreferences.node(RootPreferences.java:90)
	at org.eclipse.core.internal.preferences.PreferencesService$5.run(PreferencesService.java:623)
	at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
	at org.eclipse.core.internal.preferences.PreferencesService.getNodes(PreferencesService.java:607)
	at org.eclipse.core.internal.preferences.PreferencesService.getBoolean(PreferencesService.java:477)
	at org.csstudio.platform.libs.epics.EpicsPlugin.installPreferences(EpicsPlugin.java:224)
	at org.csstudio.platform.libs.epics.EpicsPlugin.start(EpicsPlugin.java:155)
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
	at java.security.AccessController.doPrivileged(Native Method)
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
	at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:390)
	at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1177)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
	at org.csstudio.rap.core.preferences.ServerPreferenceNode.createChild(ServerPreferenceNode.java:211)
	at org.csstudio.rap.core.preferences.ServerPreferenceNode.getChild(ServerPreferenceNode.java:295)
	at org.csstudio.rap.core.preferences.ServerPreferenceNode.node(ServerPreferenceNode.java:467)
Oct 16, 2014 12:56:05 PM org.apache.catalina.startup.HostConfig deployWAR
INFO: Deploying web application archive /var/lib/tomcat7/webapps/apps#webopi3.3.war
Oct 16, 2014 12:56:06 PM org.csstudio.rap.core.preferences.ServerPreferenceNode load
Oct 16, 2014 4:23:10 PM org.apache.catalina.startup.HostConfig checkResources
INFO: Undeploying context [/apps/webopi]
Oct 16, 2014 4:23:11 PM org.apache.catalina.startup.HostConfig deployWAR
Oct 16, 2014 4:23:13 PM org.csstudio.rap.core.preferences.ServerPreferenceNode load
Oct 16, 2014 4:36:45 PM org.apache.catalina.startup.HostConfig checkResources
Oct 16, 2014 4:36:46 PM org.apache.catalina.startup.HostConfig deployWAR
Oct 16, 2014 4:36:48 PM org.csstudio.rap.core.preferences.ServerPreferenceNode load
Oct 16, 2014 4:38:28 PM org.apache.coyote.AbstractProtocol pause
INFO: Pausing ProtocolHandler ["http-bio-8080"]
Oct 16, 2014 4:38:28 PM org.apache.catalina.core.StandardService stopInternal
INFO: Stopping service Catalina
Oct 16, 2014 4:38:30 PM org.apache.coyote.AbstractProtocol stop
INFO: Stopping ProtocolHandler ["http-bio-8080"]
Oct 16, 2014 4:38:30 PM org.apache.coyote.AbstractProtocol destroy
INFO: Destroying ProtocolHandler ["http-bio-8080"]
Oct 16, 2014 4:38:35 PM org.apache.coyote.AbstractProtocol init
INFO: Initializing ProtocolHandler ["http-bio-8080"]
Oct 16, 2014 4:38:35 PM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 470 ms
Oct 16, 2014 4:38:35 PM org.apache.catalina.core.StandardService startInternal
INFO: Starting service Catalina
Oct 16, 2014 4:38:35 PM org.apache.catalina.core.StandardEngine startInternal
INFO: Starting Servlet Engine: Apache Tomcat/7.0.28
Oct 16, 2014 4:38:35 PM org.apache.catalina.startup.HostConfig deployDescriptor
INFO: Deploying configuration descriptor /etc/tomcat7/Catalina/localhost/docs.xml
Oct 16, 2014 4:38:41 PM org.apache.catalina.util.SessionIdGenerator createSecureRandom
INFO: Creation of SecureRandom instance for session ID generation using [SHA1PRNG] took [6,442] milliseconds.
Oct 16, 2014 4:38:41 PM org.apache.catalina.startup.HostConfig deployDescriptor
INFO: Deploying configuration descriptor /etc/tomcat7/Catalina/localhost/examples.xml
Oct 16, 2014 4:38:42 PM org.apache.catalina.startup.TaglibUriRule body
INFO: TLD skipped. URI: http://java.sun.com/jstl/core_rt is already defined
INFO: TLD skipped. URI: http://java.sun.com/jstl/core is already defined
INFO: TLD skipped. URI: http://java.sun.com/jsp/jstl/core is already defined
INFO: TLD skipped. URI: http://java.sun.com/jstl/fmt_rt is already defined
INFO: TLD skipped. URI: http://java.sun.com/jstl/fmt is already defined
INFO: TLD skipped. URI: http://java.sun.com/jsp/jstl/fmt is already defined
INFO: TLD skipped. URI: http://java.sun.com/jsp/jstl/functions is already defined
INFO: TLD skipped. URI: http://jakarta.apache.org/taglibs/standard/permittedTaglibs is already defined
INFO: TLD skipped. URI: http://jakarta.apache.org/taglibs/standard/scriptfree is already defined
INFO: TLD skipped. URI: http://java.sun.com/jstl/sql_rt is already defined
INFO: TLD skipped. URI: http://java.sun.com/jstl/sql is already defined
INFO: TLD skipped. URI: http://java.sun.com/jsp/jstl/sql is already defined
INFO: TLD skipped. URI: http://java.sun.com/jstl/xml_rt is already defined
INFO: TLD skipped. URI: http://java.sun.com/jstl/xml is already defined
INFO: TLD skipped. URI: http://java.sun.com/jsp/jstl/xml is already defined
Oct 16, 2014 4:38:42 PM org.apache.catalina.startup.HostConfig deployDescriptor
INFO: Deploying configuration descriptor /etc/tomcat7/Catalina/localhost/manager.xml
INFO: Deploying configuration descriptor /etc/tomcat7/Catalina/localhost/host-manager.xml
Oct 16, 2014 4:38:42 PM org.apache.catalina.startup.HostConfig deployWAR
Oct 16, 2014 4:38:44 PM org.apache.catalina.startup.HostConfig deployWAR
Oct 16, 2014 4:38:47 PM org.apache.catalina.startup.HostConfig deployDirectory
INFO: Deploying web application directory /var/lib/tomcat7/webapps/ROOT
Oct 16, 2014 4:38:47 PM org.apache.coyote.AbstractProtocol start
INFO: Starting ProtocolHandler ["http-bio-8080"]
Oct 16, 2014 4:38:47 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in 12407 ms
Attachment: catalina.out
Description: Binary data
Oct 16, 2014 4:38:28 PM org.apache.catalina.core.ApplicationContext log
INFO: SessionListener: contextDestroyed()
INFO: ContextListener: contextDestroyed()
Oct 16, 2014 4:38:42 PM org.apache.catalina.core.ApplicationContext log
INFO: ContextListener: contextInitialized()
INFO: SessionListener: contextInitialized()
INFO: ContextListener: attributeAdded('org.apache.jasper.compiler.TldLocationsCache', 'org.apache.jasper.compiler.TldLocationsCache@157bfb')
192.168.2.57 - -  "-" 400 -
192.168.2.57 - - [16/Oct/2014:11:57:44 -0400] "GET / HTTP/1.1" 200 1895
192.168.2.57 - - [16/Oct/2014:11:57:44 -0400] "GET /favicon.ico HTTP/1.1" 404 988
192.168.2.57 - - [16/Oct/2014:11:57:47 -0400] "GET /docs/ HTTP/1.1" 200 14949
192.168.2.57 - - [16/Oct/2014:11:57:47 -0400] "GET /docs/images/tomcat.gif HTTP/1.1" 200 2066
192.168.2.57 - - [16/Oct/2014:11:57:47 -0400] "GET /docs/images/asf-logo.gif HTTP/1.1" 200 7279
192.168.2.57 - - [16/Oct/2014:11:57:50 -0400] "GET /examples/ HTTP/1.1" 200 1179
192.168.2.57 - - [16/Oct/2014:11:57:53 -0400] "GET /manager/html HTTP/1.1" 401 2486
192.168.2.57 - - [16/Oct/2014:11:58:08 -0400] "GET /examples/websocket HTTP/1.1" 302 -
192.168.2.57 - - [16/Oct/2014:11:58:08 -0400] "GET /examples/websocket/ HTTP/1.1" 200 1219
192.168.2.57 - - [16/Oct/2014:11:58:09 -0400] "GET /examples/websocket/chat.html HTTP/1.1" 200 3855
192.168.2.57 - - [16/Oct/2014:11:58:09 -0400] "GET /examples/websocket/chat HTTP/1.1" 101 -
192.168.2.57 - - [16/Oct/2014:11:58:11 -0400] "GET /examples/websocket/echo.html HTTP/1.1" 200 5456
192.168.2.57 - - [16/Oct/2014:11:58:19 -0400] "GET /examples/servlets HTTP/1.1" 302 -
192.168.2.57 - - [16/Oct/2014:11:58:19 -0400] "GET /examples/servlets/ HTTP/1.1" 200 5222
192.168.2.57 - - [16/Oct/2014:11:58:20 -0400] "GET /examples/servlets/images/execute.gif HTTP/1.1" 200 1242
192.168.2.57 - - [16/Oct/2014:11:58:20 -0400] "GET /examples/servlets/images/code.gif HTTP/1.1" 200 292
192.168.2.57 - - [16/Oct/2014:11:58:20 -0400] "GET /examples/servlets/images/return.gif HTTP/1.1" 200 1231
192.168.2.57 - - [16/Oct/2014:11:58:23 -0400] "GET /examples/servlets/servlet/HelloWorldExample HTTP/1.1" 200 347
192.168.2.57 - - [16/Oct/2014:11:58:26 -0400] "GET /examples/servlets/servlet/RequestInfoExample HTTP/1.1" 200 664
0:0:0:0:0:0:0:1 - - [16/Oct/2014:12:24:07 -0400] "GET /apps/webopi HTTP/1.1" 404 1030
0:0:0:0:0:0:0:1 - - [16/Oct/2014:12:24:07 -0400] "GET /favicon.ico HTTP/1.1" 404 988
0:0:0:0:0:0:0:1 - - [16/Oct/2014:12:24:08 -0400] "GET /favicon.ico HTTP/1.1" 404 988
192.168.2.57 - - [16/Oct/2014:13:29:29 -0400] "GET /apps/webopi HTTP/1.1" 404 1030
0:0:0:0:0:0:0:1 - - [16/Oct/2014:13:30:07 -0400] "GET /apps/webopi HTTP/1.1" 404 1030
192.168.2.57 - - [16/Oct/2014:13:35:25 -0400] "GET /app/webopi HTTP/1.1" 404 985
192.168.2.57 - - [16/Oct/2014:13:35:25 -0400] "-" 400 -
192.168.2.57 - - [16/Oct/2014:13:30:07 -0400] "-" 400 -
192.168.2.57 - - [16/Oct/2014:13:52:40 -0400] "GET /app/webopi HTTP/1.1" 404 985
0:0:0:0:0:0:0:1 - - [16/Oct/2014:13:52:47 -0400] "GET /app/webopi HTTP/1.1" 404 985
0:0:0:0:0:0:0:1 - - [16/Oct/2014:13:53:12 -0400] "GET / HTTP/1.1" 200 1895
0:0:0:0:0:0:0:1 - - [16/Oct/2014:13:53:34 -0400] "¤ ­±c 4�3¯PR��ëû�]ª#��&mT>��9¶k��F� " 400 -
192.168.2.57 - - [16/Oct/2014:16:22:30 -0400] "GET /apps/webopi HTTP/1.1" 404 1030
192.168.2.57 - - [16/Oct/2014:16:23:11 -0400] "GET /apps/webopi HTTP/1.1" 404 988
192.168.2.57 - - [16/Oct/2014:16:26:18 -0400] "GET /apps/webopi HTTP/1.1" 404 1030
192.168.2.57 - - [16/Oct/2014:16:26:38 -0400] "GET / HTTP/1.1" 304 -
192.168.2.57 - - [16/Oct/2014:16:26:47 -0400] "GET /apps/webopi HTTP/1.1" 404 1030
192.168.2.57 - - [16/Oct/2014:16:28:36 -0400] "GET /apps/webopi HTTP/1.1" 404 1030
192.168.2.57 - - [16/Oct/2014:16:30:09 -0400] "GET /apps/webopi HTTP/1.1" 404 1030
192.168.2.57 - - [16/Oct/2014:16:30:09 -0400] "GET /favicon.ico HTTP/1.1" 404 988
192.168.2.57 - - [16/Oct/2014:16:38:50 -0400] "GET /apps/webopi HTTP/1.1" 404 1030
webopi -- http status 404 error Tom Smart
Re: webopi -- http status 404 error Kasemir, Kay
Prev: Re: webopi -- http status 404 error Kasemir, Kay
Next: csstudio RAP applications Xinyu.Wu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
