1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: quadEM R5-0 now available
To: "[email protected]" <[email protected]>, "Beamline Controls and Data Acquisition" <[email protected]>
Date: Fri, 17 Oct 2014 18:35:27 +0000
Folks,
quadEM R5-0 is now available.
This is from the release notes:
- Supported a new geometry where the current sources are arranged in a square array with 2 on the top and 2 on the bottom, in addition to the previous diamond geometry of top, bottom, left right. The sum, difference and position calculations are done differently in this geometry.
- Added a new Geometry PV that controls which geometry (Diamond, Square) is used in the calculations.
- Because the diodes that contribute to the sum, difference and position calculations depend on the geometry, the names of the Sum, Diff and Position PVs have changed.
    Sum12, Sum34 have changed to SumX, SumY
    Diff12, Diff34 have changed to DiffX, DiffY
    Position12, Position34 have changed to PositionX, PositionY
    Sum1234 has changed to SumAll
The home page is here:
http://cars.uchicago.edu/software/epics/quadEM.html
The documentation is here:
http://cars.uchicago.edu/software/epics/quadEMDoc.html
The release notes are here:
http://cars.uchicago.edu/software/epics/quadEMReleaseNotes.html
Let me know of any problems or suggestions.
Prev: Re: EPICS on vxWorks Andrew Johnson
Next: Re: Binding an IOC to a single network interface Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: areaDetector ADCore and ADBinaries R2-1 released Mark Rivers
Next: Trouble building debug version of areaDetector 2.x (from git) John Hammonds
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
