Hi Lewis,
> On Oct 23, 2014, at 00:07, J. Lewis Muir <[email protected]> wrote:
>> On 10/22/14 4:45 PM, Johnson, Andrew N. wrote:
>> I would be careful with making assumptions about using “plug-in”
>> programs, the GPLv3 definition for Corresponding Source "includes
>> interface definition files associated with source files for the work,
>> and the source code for shared libraries and dynamically linked
>> subprograms that the work is specifically designed to require,
>> such as by intimate data communication or control flow between
>> those subprograms and other parts of the work.” This means that
>> “intimate” inter-program communication could also require your
>> program to be released under the GPL in some cases.
> See:
> http://www.gnu.org/licenses/gpl-faq.html#GPLAndPlugins
> To me, that supports what I said.
Read the following FAQ points as well, there are subtle distinctions between whether your main application is GPL or your plugin is GPL, and I think the example you pointed to was for a non-GPL plugin to a GPL application.
- Andrew
Sent from my iPad
- Re: Discussion about licenses, copyrights, business, and source code J. Lewis Muir
- Discussion about licenses, copyrights, business, and source code Emmanuel Mayssat
- Re: Discussion about licenses, copyrights, business, and source code Johnson, Andrew N.
Re: AsynPortDriver setting DRVH of ao? Florian Feldbauer
Re: PV monitoring and email reporting tool Johnson, Andrew N.
<2014>
<2014>
