1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem with CSS archive engine
To: 龙巍 <[email protected]>
Cc: "<[email protected]>" <[email protected]>
Date: Tue, 28 Oct 2014 13:37:45 +0000
Hi:
To fix your immediate problem, OutOfMemoryError, you can run the archive engine with more memory.
Use command-line options ending in
  ArchiveEngine -pluginCustomization ….. -vmargs -Xmx1024m
to pass suitable -Xm* options.
But a  waveform PV of 2048 points at 25Hz will lead to other problems.
This archive system is for long-term monitoring of the control system.
It's for monitoring temperatures, voltages etc. over days, months, storing them into one continuous archive.
It's not a data-aquisition system for capturing data that is fast but specific to one experiement.
Such data is usually captured by a data acquisition system for the duration of one experiment, then saved to a set of files, and users take those files home.
While the generic archive can save waveforms, there's currently no good tool to view the waveforms. One reason is that a waveform usually lacks information:
What is the "X" axis of the waveform data??
Kay
On Oct 21, 2014, at 10:39 PM, 龙巍 <[email protected]>
 wrote:
> Now the IOC time is synchronized with the NTP server and works well. But there is still the problem.
> Here is the message(by the way: The waveform PV has 2048 points (double value), and the updating frequence is 25HZ):
> D:\cssAchiver\eclipse>ArchiveEngine.exe -engine Demo -pluginCustomization test.i
> ni
> 2014-10-22 10:14:20.505 配置 [Thread 1] org.csstudio.vtype.pv.internal.Activator
> (start) - PV prefix ca provided by JCA in org.csstudio.vtype.pv
> 2014-10-22 10:14:20.521 配置 [Thread 1] org.csstudio.vtype.pv.internal.Activator
> (start) - PV prefix loc provided by Local in org.csstudio.vtype.pv
> 2014-10-22 10:14:20.537 配置 [Thread 1] org.csstudio.vtype.pv.internal.Activator
> (start) - Default PV type ca
> 2014-10-22 10:14:20.537 信息 [Thread 1] org.csstudio.archive.engine.Application
> (start) - Archive Engine 3.3.0.201406061208
> 2014-10-22 10:14:20.724 信息 [Thread 1] org.csstudio.archive.engine.server.Engin
> eServer (<init>) - Engine HTTP Server on http://localhost:4812/main
> 2014-10-22 10:14:20.724 信息 [Thread 1] org.csstudio.archive.engine.Application
> (start) - Reading configuration 'Demo'
> 2014-10-22 10:14:21.317 信息 [Thread 1] org.csstudio.archive.engine.Application
> (start) - Read configuration: 1 channels in 0.58 seconds
> (start) - Running, CA addr list: 192.168.0.66
> 2014-10-22 10:14:21.317 信息 [Thread 46] org.csstudio.archive.engine.model.Write
> Thread (run) - WriteThread starts
> 2014-10-22 10:14:21.348 配置 [Thread 1] org.csstudio.vtype.pv.jca.JCAContext (<i
> nit>) - Using Pure Java CAJ
> 2014-10-22 10:14:21.582 信息 [Thread 55] org.csstudio.archive.engine.scanner.Sca
> nThread (run) - Scan Thread runs
> 2014-10-22 10:14:51.378 警告 [Thread 52] org.csstudio.archive.engine.ThrottledLo
> gger (log) - rcs:cpci9110:wf_6_a: 145 overruns
> 2014-10-22 10:14:51.659 警告 [Thread 51] org.csstudio.archive.engine.ThrottledLo
> gger (log) - rcs:cpci9110:wf_6_a: 6 overruns
> ... More messsages suppressed for 1.00 days ....
> Exception in thread "qtp1943325854-30" Exception in thread "WriteThread" java.la
> ng.OutOfMemoryError: GC overhead limit exceeded
>        at java.util.ArrayList.iterator(Unknown Source)
> Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler i
> Exception in thread "qtp1943325854-43" java.lang.OutOfMemoryError: GC overhead l
> imit exceeded
>        at sun.util.locale.BaseLocale.getInstance(Unknown Source)
>        at java.util.Locale.getInstance(Unknown Source)
>        at java.util.ResourceBundle$Control$CandidateListCache.getDefaultList(Un
> known Source)
>        at java.util.ResourceBundle$Control$CandidateListCache.createObject(Unkn
> own Source)
> own Source)
>        at sun.util.locale.LocaleObjectCache.get(Unknown Source)
>        at java.util.ResourceBundle$Control.getCandidateLocales(Unknown Source)
>        at sun.util.resources.LocaleData$LocaleDataResourceBundleControl.getCand
>        at java.util.ResourceBundle.getBundleImpl(Unknown Source)
>        at java.util.ResourceBundle.getBundle(Unknown Source)
>        at sun.util.resources.LocaleData$1.run(Unknown Source)
>        at java.security.AccessController.doPrivileged(Native Method)
>        at sun.util.resources.LocaleData.getBundle(Unknown Source)
>        at sun.util.resources.LocaleData.getDateFormatData(Unknown Source)
>        at java.text.DateFormatSymbols.initializeData(Unknown Source)
>        at java.text.DateFormatSymbols.<init>(Unknown Source)
>        at sun.util.locale.provider.DateFormatSymbolsProviderImpl.getInstance(Un
> known Source)
>        at java.text.DateFormatSymbols.getProviderInstance(Unknown Source)
>        at java.text.DateFormatSymbols.getInstance(Unknown Source)
>        at java.util.Calendar.getDisplayName(Unknown Source)
>        at java.text.SimpleDateFormat.subFormat(Unknown Source)
> Exception in thread "qtp1943325854-36" Exception in thread "qtp1943325854-61" Ex
> ception in thread "qtp1943325854-31" Exception in thread "pool-1-thread-1"
> Exception in thread "pool-1-thread-3" java.lang.OutOfMemoryError: GC overhead li
> mit exceeded
> Exception in thread "qtp1943325854-41" java.lang.OutOfMemoryError: GC overhead l
> imit exceeded
> Exception in thread "qtp1943325854-65" Exception in thread "qtp1943325854-29" Ex
> ception in thread "Thread-1" Exception in thread "qtp1943325854-35" Exception in
> thread "qtp1943325854-58" Exception in thread "qtp1943325854-59" java.lang.OutO
> Exception in thread "qtp1943325854-45"
> Exception in thread "qtp1943325854-60" java.lang.OutOfMemoryError: GC overhead l
> imit exceeded
> Exception in thread "qtp1943325854-57" Exception in thread "qtp1943325854-53" ja
> va.lang.OutOfMemoryError: GC overhead limit exceeded
> java.lang.OutOfMemoryError: GC overhead limit exceeded
>        at java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject
> .addConditionWaiter(Unknown Source)
> .awaitNanos(Unknown Source)
>        at org.eclipse.jetty.util.BlockingArrayQueue.poll(BlockingArrayQueue.jav
> a:342)
>        at org.eclipse.jetty.util.thread.QueuedThreadPool.idleJobPoll(QueuedThre
> adPool.java:526)
>        at org.eclipse.jetty.util.thread.QueuedThreadPool.access$600(QueuedThrea
> dPool.java:44)
>        at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool
> .java:572)
>        at java.lang.Thread.run(Unknown Source)
> Exception in thread "qtp1943325854-71" java.lang.OutOfMemoryError: GC overhead l
> imit exceeded
> Exception in thread "com.cosylab.epics.caj.util.Timer" java.lang.OutOfMemoryErro
>> -----原始邮件-----
>> 发件人: "Johnson, Andrew N." <[email protected]>
>> 发送时间: 2014年10月21日 星期二
>> 收件人: "龙巍" <[email protected]>
>> 抄送: "[email protected]" <[email protected]>
>> 主题: Re: Problem with CSS archive engine
>> By default a VxWorks IOC tries to synchronize its OS clock with an NTP server running on its boot host, but if you have NTP available from a different IP address you can configure that by setting the environment variable EPICS_TS_NTP_INET. You may also need to set the EPICS_TIMEZONE variable to your local timezone, see the comments in the base/configure/CONFIG_SITE_ENV file for details of the format of that variable.
>> - Andrew
>> Sent from my iPad
>>> On Oct 21, 2014, at 10:50, 龙巍 <[email protected]> wrote:
>>> hello Ralph,
>>> Thanks for your suggestions,I got the date from the IOC shell:
>>> ->date
>>> 1990/01/02 00:45:24.212000
>>> Just like you said, the IOC was not able to synchronize its time. But I
>>> don't know how to do.
>>> Can you give me some advice?
>>> And, there is a warning when the IOC start:
>>> ## EPICS R3.14.12.1 $Date: Tue 2011-04-26 15:36:19 -0500$
>>> ## EPICS Base built May 30 2014
>>> WARNING: OS Clock time was read before being set.
>>> Using 1990-01-02 00:00:00.000000 UTC
>>> iocRun: All initialization complete
>>> Our IOC runs on the VxWorks OS system.
>>> So .. is anyone know how to set the OS Clock time?
Re: Problem with CSS archive engine 龙巍
Re: Problem with CSS archive engine Johnson, Andrew N.
Prev: Re: EPICS Saclay Meeting oct 2014 Benjamin Franksen
Next: RE: Focus deadlock --solved Specht, Eliot D.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Problem with CSS archive engine 龙巍
Next: Re: Problem with CSS archive engine 龙巍
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
