1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: galil softIOC lose the galil controller
To: "[email protected] ([email protected])" <[email protected]>
Cc: Mark Clift <[email protected]>
Date: Thu, 30 Oct 2014 13:25:42 +0000
Dear Mark,
thank you for your instructions. I followed them, but still about after 4 hours the rio's are no more ping-able.
epics@ioc163:~$ ping 10.0.0.210
PING 10.0.0.210 (10.0.0.210) 56(84) bytes of data.
^C
--- 10.0.0.210 ping statistics ---
7 packets transmitted, 0 received, 100% packet loss, time 6047ms
epics@ioc163:~$ ping 10.0.0.211
PING 10.0.0.211 (10.0.0.211) 56(84) bytes of data.
^C
--- 10.0.0.211 ping statistics ---
2 packets transmitted, 0 received, 100% packet loss, time 999ms
epics@ioc163:~$ arp -a
? (10.0.0.211) at 00:50:4c:28:1a:dd [ether] PERM on eth0
? (10.0.0.45) at 18:03:73:d2:93:af [ether] on eth0
? (10.0.0.47) at 90:b1:1c:8b:8b:cd [ether] on eth0
? (10.0.0.2) at 00:0c:29:55:30:01 [ether] on eth0
? (10.0.0.210) at 00:50:4c:28:1a:de [ether] PERM on eth0
? (10.0.0.8) at d8:d3:85:58:e7:4b [ether] on eth0
? (10.0.0.46) at 90:b1:1c:8b:87:50 [ether] on eth0
? (10.0.0.1) at d8:d3:85:a5:13:9e [ether] on eth0
epics@ioc163:~$ route
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
default         10.0.0.8        0.0.0.0         UG    0      0        0 eth0
10.0.0.0        *               255.255.254.0   U     0      0        0 eth0
224.0.0.0       *               240.0.0.0       U     0      0        0 eth0
they both end up with:
10.0.0.210:
epics> acquireDataRecord:1151 TIMEOUT ERROR.  Galil::record("DR") took longer than 500 ms to read 56 bytes
GalilController::get_double:GalilController::writeReadController:epics[2]=?:1011 TIMEOUT ERROR.  Galil::command("epics[2]=?") took longer than 500 ms to read : response.
GalilController::get_double:GalilController::writeReadController:epics[1]=?:1011 TIMEOUT ERROR.  Galil::command("epics[1]=?") took longer than 500 ms to read : response.
Disconnected from RIO47100 Rev 1.1h at 10.0.0.210
connect: 5004 OPEN ERROR.  Galil::Galil() failed to open Ethernet host 10.0.0.210
10.0.0.211:
GalilController::get_double:GalilController::writeReadController:epics[5]=?:1011 TIMEOUT ERROR.  Galil::command("epics[5]=?") took longer than 500 ms to read : response.
GalilController::get_double:GalilController::writeReadController:epics[6]=?:1011 TIMEOUT ERROR.  Galil::command("epics[6]=?") took longer than 500 ms to read : response.
GalilController::get_double:GalilController::writeReadController:epics[3]=?:1011 TIMEOUT ERROR.  Galil::command("epics[3]=?") took longer than 500 ms to read : response.
Disconnected from RIO47100 Rev 1.1h at 10.0.0.211
connect: 5004 OPEN ERROR.  Galil::Galil() failed to open Ethernet host 10.0.0.211
Any idea?
All the best,
Heinz
On 30.10.2014, at 09:47, Mark Clift <[email protected]> wrote:
> Hi Heinz,
> Please follow this setup procedure for the RIO PLC.
> 1.  Use GalilTools to set the IP address
> 2.  Record the MAC address of the RIO
> 3.  Edit /etc/rc.d/rc.local and add the following:
> # Add multicast route for Galil hardware
> route add -net 224.0.0.0 netmask 240.0.0.0 dev eth0
> # Add arp entry for Galil RIO device
> arp -s <IPADDRESS> <MACADDRESS>
> 4.  Reboot softIOC or type above commands as root, then exit root login
> 5.  Telnet into RIO from softIOC, and issue the following commands
> :IB1   (Possibly IK1 on some firmware)
> :BN   (Burn the changes)
> :^M
> exit
> 6.  From now on only hosts with the arp entry can telnet into RIO
> Then try the IOC again.  I recommend using a single IOC and connection to the RIO.
> Also try the email again.
> Best wishes,
> Mark.
> Dr. Mark Clift
> Senior Controls Engineer
> Australian Synchrotron
> 800 Blackburn Road
> Clayton 3168
> Ph: +613 8540 4264
> Fax: +613 8540 4200
> Mail: [email protected]
> From: Heinz Junkes [[email protected]]
> Sent: Thursday, 30 October 2014 19:16
> To: Mark Clift
> Cc: [email protected] ([email protected])
> Hi techtalk,
> we are running two galil RIO-47120 controllers. We are using the newest versions of galilsuite and galiltools on debian linux.
> ii  galilsuite                          1.0.2                               amd64        Test GalilSuite build
> ii  galiltools                          1.6.3                               amd64        GalilTools
> and the Galil-3-0 motorapp.
> We could'nt get them running stable. Until the day before yesterday I connected to both controllers with one softioc. About every second week they stopped working and the controllers could'nt be ping-ed anymore. We have to reset the controllers. Both stopped at the same time.
> Now I run two softioc's on the same Unix-System. Each of them opens a connection to a single controller ... now they sopped working after about 5-6 hours.
> And again both of them at the same time. I have no info's in any log-file.
> The program on the IOC is very simple:
> dmc-file, rioDIag.dmc :
> 'Galil Motion Control [email protected]
> 'http://www.galilmc.com/
> #epics
> 'Insert code to run on
> ' GalilStartController() here...
> MA 141,14,141,214;
> MD [email protected];
> MS [email protected];
> WT 100
> XQ#update,1;'spawn update thread
> EN
> #update;'Example update loop
> AT0
> epics[0]=TIME;'time tick
> epics[1]=_OP0
> epics[2]=_TI0
> OPepics[9]
> IF (epics[10])
> SB8
> WT50
> CB8
> epics[10]=0
> ENDIF
> AT200;'see SCAN field in
> ' galil_array_access.substitutions
> JP#update
> #CMDERR;'runs if an error occurs
> MG "An error occured at line",_ED
> TC 1;'print type of error info
> ZS;'Remove returns from callbck
> EN;'End execution
> #TCPERR
> MG {M} "TCPERR.  Dropped handle", _IA4
> RE
> started with this cmd-file, rioDiag.cmd:
> #Galil Motion Control [email protected] http://www.galilmc.com/
> #Load Galil Data Record Support
> #dbLoadTemplate("$(TOP)/GalilDiagApp/Db/rioDiag_motor.substitutions")
> #Provide access to Galil Array Table
> dbLoadTemplate("$(TOP)/GalilDiagApp/Db/rioDiag_array_access.substitutions")
> # GalilCreateController command parameters are:
> # 1. Const char *portName - The name of the asyn port to be created for this controller
> # 2. Const char *address  - The address of the controller
> # 3. int numAxes          - The number of axis that will be used on the controller
> # 4. double updatePeriod  - The time in ms between datarecords
> #   (See controller's DR command for minimum).
> #   Async if controller + bus supports it, otherwise is polled/synchronous.
> GalilCreateController("rioDiag", "10.0.0.210", 1, 32)
> #GalilCreateController("rioDiag", "141.14.128.41", 2, 8)
> # GalilCreateAxis command parameters are:
> # 1. char *portName Asyn port for controller
> # 2. char axis A-H,
> GalilCreateAxis("rioDiag","A")
> #GalilCreateAxis("rioDiag","B")
> #GalilCreateAxis("Galil","C")
> #GalilCreateAxis("Galil","D")
> #GalilCreateAxis("Galil","E")
> #GalilCreateAxis("Galil","F")
> #GalilCreateAxis("Galil","G")
> #GalilCreateAxis("Galil","H")
> # GalilStartController command parameters are:
> # 2. char *code file to deliver to the controller, "" for none.
> # 3. char *label to execute on file, "" to not execute.
> GalilStartController("rioDiag", "rioDiag.dmc", "#epics")
> and this st.cmd:
> #!../../bin/linux-x86_64/GalilDiagApp
> epicsEnvSet("ARCH","linux-x86_64")
> epicsEnvSet("IOC","IOCRIODIAG")
> epicsEnvSet("TOP","/srv/ioc/sys/$(IOC)")
> #epicsEnvSet("SUPPORT","/home/epics/EPICS/support")
> #epicsEnvSet("EPICS_BASE","/home/epics/EPICS/base")
> #epicsEnvSet("ASYN","/home/epics/EPICS/support/asyn/asyn4-22")
> #epicsEnvSet("MOTOR","/home/epics/EPICS/support/motor/motorR6-8")
> epicsEnvSet("DISPLAY",":0")
> epicsEnvSet("LOG_DIR", "/srv/ioc/log")
> ## Register all support components
> dbLoadDatabase("$(TOP)/dbd/GalilDiagApp.dbd",0,0)
> GalilDiagApp_registerRecordDeviceDriver(pdbbase)
> # Configure an example controller
> #< rioMezz.cmd
> < rioDiag.cmd
> #dbLoadRecords ("$(TOP)/db/rioMezz.db","P=FHIFEL:,R=HELPER:,S=GUNRELAY:")
> dbLoadRecords("$(TOP)/db/attenuator.db","P=FHIFEL:,R=DIAG:,S=ATTENUATOR:")
> dbLoadRecords("$(TOP)/db/flipper.db","P=FHIFEL:,R=DIAG:,S=FLIP:")
> #dbLoadRecords("$(TOP)/db/checkAlive.db","RIO=rioMezz:")
> dbLoadRecords("$(TOP)/db/checkAlive.db","RIO=rioDiag:")
> ## autoSaveRestore setup
> save_restoreSet_Debug(0)
> # status-PV prefix, so save_restore can find its status PV's.
> save_restoreSet_status_prefix("${IOC}:")
> # ok to restore a save set that had missing values (no CA connection to PV)?
> # ok to save a file if some CA connections are bad?
> save_restoreSet_IncompleteSetsOk(1)
> #In the restore operation, a copy of the save file will be written.  The
> # file name can look like "auto_settings.sav.bu", and be overwritten every
> # reboot, or it can look like "auto_settings.sav_020306-083522" (this is what
> # is meant by a dated backup file) and every reboot will write a new copy.
> save_restoreSet_DatedBackupFiles(1)
> # specify where save files should go
> set_savefile_path("/srv/ioc/log/as","/save")
> # specify where request files can be found
> set_requestfile_path("/srv/ioc/log/as","/req")
> # Specify what save files should be restored when.
> # Up to eight files can be specified for each pass.
> set_pass0_restoreFile("${IOC}_0.sav")
> set_pass1_restoreFile("${IOC}_1.sav")
> # Number of sequenced backup files (e.g., 'auto_settings.sav0') to write
> save_restoreSet_NumSeqFiles(3)
> save_restoreSet_SeqPeriodInSeconds(600)
> # Time between failed .sav-file write and the retry.
> save_restoreSet_RetrySeconds(60)
> iocInit()
> makeAutosaveFileFromDbInfo("/srv/ioc/log/as/req/${IOC}_0.req", "autosaveFields_pass0")
> makeAutosaveFileFromDbInfo("/srv/ioc/log/as/req/${IOC}_1.req", "autosaveFields_pass1")
> create_monitor_set("${IOC}_0.req", 5, "P=${IOC}:")
> create_monitor_set("${IOC}_1.req", 30, "P=${IOC}:")
> ## Report Installed and Configured I/O-Hardware Information
> dbior 0 1 > ${LOG_DIR}/Database/${IOC}.dbior
> dbhcr     > ${LOG_DIR}/Database/${IOC}.dbhcr
> dbl       > ${LOG_DIR}/Database/${IOC}.dbl
> By the way, the mail-sending on RIO works only once or twice .. then it stops sending any mails
> Best regards,
> Heinz
> On 30.10.2014, at 01:17, Mark Clift <[email protected]> wrote:
>> Hi Qingru,
>> I would guess that the multi-cast route is missing, which is required for the Galil driver you're using.
>> We add the following line into /etc/rc.local
>> The error simply says it could not poll the first 8 digital inputs with Galil TI (Tell input) command.
>> Also there is a newer Galil driver designed to replace the one your using located here:
>> http://motorapp.github.io/Galil-3-0/
>> Best wishes,
>> Mark
>> Dr. Mark Clift
>> 800 Blackburn Road
>> Clayton 3168
>> Ph: +613 8540 4264
>> Fax: +613 8540 4200
Attachment: smime.p7s
Description: S/MIME cryptographic signature
galil softIOC lose the galil controller Mark Clift
Re: galil softIOC lose the galil controller Heinz Junkes
RE: galil softIOC lose the galil controller Mark Clift
Prev: RE: areaDetector 2.0 on windows xp 32bit Mark Rivers
Next: Re: galil softIOC lose the galil controller Pearson, Matthew R.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: galil softIOC lose the galil controller Mark Clift
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
