1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Disable database question
From: "Zelazny, Michael Stanley" <[email protected]>
Date: Thu, 30 Oct 2014 18:07:05 +0000
If you use the SDIS approach, please think about whether you want to use a database link or a channel access link.
If you use a database link you're database will be in one giant lock set which, I have discovered, can dramatically change the way your IOC behaves.
From: [email protected] [[email protected]] on behalf of Andrew Johnson [[email protected]]
Sent: Thursday, October 30, 2014 10:57 AM
To: [email protected]
Subject: Re: Disable database question
[snip]
If you want the IOC to stay alive and visible to the outside world then
Bob's suggestion of pointing all the record's SDIS links (which he
mis-spelled as DISL) to a single "ioc enable" PV would probably be
better. There is a brief description of this mechanism at
https://wiki-ext.aps.anl.gov/epics/index.php/RRM_3-14_dbCommon#Scan_Fields
HTH,
- Andrew
People everywhere confuse what they read in newspapers with news.
-- A. J. Liebling
Disable database question Elmer Pensack
Re: Disable database question Andrew Johnson
Prev: Re: Disable database question Ralph Lange
Next: Re: EPICS Saclay Meeting oct 2014 Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Disable database question Andrew Johnson
Next: Re: Disable database question Hu, Yong
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
