1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: waveform with single element
To: Vishnu Patel <[email protected]>, techtalk <[email protected]>
Date: Fri, 31 Oct 2014 13:20:32 -0500
Hi Vishnu,
On 10/31/2014 10:51 AM, Vishnu Patel wrote:
> I am facing problem with waveform record in EPICS 3.15.
> If i use waveform record with single element NELM=1,
> The pv value on camonitor always give zero even though it is non-zero value.
> This was working fine in EPICS3.14.
Please post the evidence that leads you to this conclusion. If possible
please demonstrate it using just the softIoc and the command-line client
programs caget/caput/cainfo/camonitor. I can't see any differences
between the two, but I'm probably not doing the same things you are.
> What extra caution should take for single element waveform record in
> epics 3.15?
There should be no difference between in array channel behaviour between
3.14. and 3.15. There have been some changes to the waveform record, but
they shouldn't affect single-element arrays specifically.
- Andrew
People everywhere confuse what they read in newspapers with news.
-- A. J. Liebling
waveform with single element Vishnu Patel
Prev: Re: devAsynFloat64::initCommon findInterface asynFloat64Type Pearson, Matthew R.
Next: RE: devAsynFloat64::initCommon findInterface asynFloat64Type Heesterman, Peter J
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: waveform with single element Zelazny, Michael Stanley
Next: devAsynFloat64::initCommon findInterface asynFloat64Type Heesterman, Peter J
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
