> Comparisons between numbers and non-numbers (such as NaN) are
> undefined.
Not quite: comparisons involving NaN are defined to always return false. This means that a test of the form
if (prec->drvl <= value && value <= prec->drvh)
// accept value
else
// reject value
would have the desired effect (and setting a drv limit would cause all values to be rejected!)
> What is your suggestion on how to check limits for a non-number without
> using comparisons?
> > We also found that you can type "NaN" at any entry field in DM2K
> which
> > writes NaN directly to the PV.
> NaN, -inf and +inf are valid values for a double. Why would you reject
> entering valid values in entry fields?
> Cheers,
> ~Ralph
- Re: NaN and analog records Dirk Zimoch
- NaN and analog records Benjamin Franksen
- Re: NaN and analog records Goetz Pfeiffer
- Re: NaN and analog records Ralph Lange
support for NIKHEF Hall probes Pierrick Hanlet
<2014>
Re: NaN and analog records Benjamin Franksen
<2014>
