1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Compiling SDDS problem
To: "Xue, Chen" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 4 Nov 2014 22:34:13 +0000
Hi Chen,
I made the following changes to get burt to build with SDDS 3.2.1
Janet
Index: Makefile
RCS file: /usr/local/epicsmgr/cvsroot/epics/extensions/src/burt/Makefile,v
retrieving revision 1.15
retrieving revision 1.17
diff -r1.15 -r1.17
10c10
< # $Id: Makefile,v 1.15 2013/01/11 21:34:18 jba Exp $
> # $Id: Makefile,v 1.17 2014/07/11 20:43:52 jba Exp $
34c34
< USR_LIBS += namelist
> USR_LIBS += lzma
41d40
< USR_LIBS_Linux += Xp Xext X11
47c46
< namelist_DIR = $(EPICS_EXTENSIONS_LIB)
> lzma_DIR     = $(EPICS_EXTENSIONS_LIB)
51,52d49
< Xp_DIR       = $(X11_LIB)
< Xext_DIR     = $(X11_LIB)
64a62
76c74
< USR_CXXFLAGS_Linux =  -fno-const-strings
> #####USR_CXXFLAGS_Linux =  -fno-const-strings
Index: burt.notes
RCS file: /usr/local/epicsmgr/cvsroot/epics/extensions/src/burt/burt.notes,v
retrieving revision 1.9
retrieving revision 1.10
diff -r1.9 -r1.10
39a40,42
> Fri Jul 11 15:40:55 CDT 2014  burt_20140711
>       Modified to build and run with SDDS 3.2.1 and later.
From: [email protected] [[email protected]] on behalf of Chen Xue [[email protected]]
Sent: Tuesday, November 04, 2014 3:30 PM
To: [email protected]
Subject: Re: Compiling SDDS problem
Thanks for help. After I installed libxaw7-dev, SDDS compiling problem was
solved.
Now when I compiled BURT, I have an error message below.
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64 install
/bin/sh: 1: [: Illegal number: (Debian
make[1]: Entering directory
`/opt/epics/extensions/src/burt_20130124/O.linux-x86_64'
/usr/bin/g++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux
-D_REENTRANT   -O3 -g   -Wall    -I../../../templates/List -I/usr/include
-I/usr/include -DNODEVICES -USUN4 -fno-const-strings  -m64      -MMD -I.
-I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include
-I../../../../base/include/os/Linux -I../../../../base/include
-I../../../include         ../burtrb.cc
g++: error: unrecognized command line option ‘-fno-const-strings’
make[1]: *** [burtrb.o] Error 1
make[1]: Leaving directory
make: *** [install.linux-x86_64] Error 2
How could I get around this problem?
Thanks!
Chen
> Hi,
> We need EPICS extension BURT, which requires SDDS package. We are using
> 64bit Linux Debian and base-3.14.12.4. I downloaded SDDS.3.2.tar.gz and
> burt_20130124.tar.gz.
> When I compiled SDDS, I encounted the following error.
> /usr/bin/g++ -o sddsplot  -L/opt/epics/extensions/lib/linux-x86_64
> -Wl,-rpath,/opt/epics/extensions/lib/linux-x86_64       -m64
> SDDSaps.o put_link_date.o sddsplot.o sddsplotAP.o sddsplotConvert.o
> sddsplotFilter.o sddsplotLabels.o sddsplotMapping.o sddsplotRead.o
> sddsplotRecord.o sddsplotXfer.o sddsplotGroup.o    -lmdbplt -lgd -lpng
> -lmdbplt -lmdbcommon -lmatlib -lfftpack -lSDDS1 -lrpnlib -lmdbmth -lmdblib
> -llzma  -lfontconfig -lz -lrt -lpthread   -lreadline -lm -lrt -ldl
> -L/usr/lib/x86_64-linux-gnu -lXaw -lXmu -lXt -lXext -lX11 -lgcc
> /usr/bin/ld: cannot find -lXaw
> collect2: error: ld returned 1 exit status
> make[2]: *** [sddsplot] Error 1
> make[2]: Leaving directory
> `/opt/epics/extensions/src/SDDS/SDDSaps/sddsplots/O.linux-x86_64'
> make[1]: *** [install.linux-x86_64] Error 2
> `/opt/epics/extensions/src/SDDS/SDDSaps/sddsplots'
> make: *** [SDDSaps/sddsplots.install] Error 2
> Could anyone help me on this problem?
> Thanks,
> Chen
Compiling SDDS problem Chen Xue
Re: Compiling SDDS problem Chen Xue
Prev: Re: Compiling SDDS problem Bob Soliday
Next: Re: read waveform data using ca_create_subscription Bruce Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: autosave R5-5 Mooney, Tim M.
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
